Go Back   Home > Forums > General Interest > Car Audio
Old 4th November 2010, 10:20 PM   #1
Default Sundown SAZ 3000 D
I replaced the rectifiers in this amp due to broken legs. Amp powerd up and produced audio perfectly.
Returned the amp to the customer and he said it was stuck in protection mode so i got the amp back and sure enough its stuck in protection mode.
So i removed the rectifiers and its still in protection so i put thoose back in i removed the output driverboard and no different.
Here what i have on the 494
1:8.67
2:2.62
3:4.92
4:4.29
5:1.51
6:3.78
7:0
8:13.90
9:0
10:0
11:13.89
12:13.89
13:5.08
14:5.08
15:5.08
16:0
Any ideas on what to check?
Old 4th November 2010, 11:49 PM   #2
if you removed the rectifiers and it is still in protect i think the problem is in the power supply area
Old 5th November 2010, 02:00 AM   #3
Can you send me a high resolution photo of the area around the 494 IC (showing all ICs in the area)?
babin_perry@yahoo.com
Old 5th November 2010, 02:06 AM   #4
Ill see if i have another cord for my camera since the the one i have doent work.
There are no other IC's anywhere near the 494 just a transistor c3198 and caps and resistors
Old 5th November 2010, 02:33 AM   #5
What's driving pin 1 of the 494?
Old 5th November 2010, 03:03 AM   #6
I found a LM293 at the other end of the board
voltages on that ic are
1:9.28
2:2.55
3:.07
4:0
5:2.17
6:4.12
7:9.28
8:13.89
Old 5th November 2010, 03:04 AM   #7
Does it appear that any of the outputs from that IC are driving pin 1 of the 494?
Old 5th November 2010, 03:10 AM   #8
doeant look like it.
The C3198 goes to some resistors and then to pin 1 of the 494
The 3198 voltages are
1:4.29
2:5.08
3:4.92
Old 5th November 2010, 03:24 AM   #9
Pin 1 has 8+ volts on it. It can't be coming from the 3198.
Old 5th November 2010, 03:33 AM   #10
Looks like pin 1 of the 494 goes through some resistors and diodes and then goes to pin 7 of the 293
Sundown SAE-1200Dv1 Weird output issue possible Fet problem? RosDaddy Car Audio 7 11th April 2010 02:12 AM
Sundown Audio SAE-1200D stuck in protect spooney Car Audio 16 12th March 2010 09:35 PM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
3000 posts! Elso Kwak The Lounge 39 11th March 2006 05:45 PM
Page generated in 0.09676 seconds (76.49% PHP - 23.51% MySQL) with 11 queries
