Go Back   Home > Forums > General Interest > Car Audio
Old 29th October 2010, 02:29 AM   #1
RiLoWa is offline RiLoWa  United States
RiLoWa's Avatar
Default Alpine MRP-M350
This amp has two IRF5305 and two IRFZ44N on the outputs. I found that one of the IRF5305's is shorted. I then removed all of the outputs to confirm they are ok, which they seem to be. When powering this amp with out any outputs installed, the power LED pulses and it makes a "squeaking" sound.
This is the first Class D amp I have attempted to work on. Does this amp require good outputs to be installed in order to power up correctly OR is there some other problem upstream from the outputs?
The attached picture was taken just after I removed the one bad output.
Old 29th October 2010, 02:51 AM   #2
If the half with the missing output is causing DC to appear on the speaker terminals, it could be going into protect.
Old 29th October 2010, 02:59 AM   #3
RiLoWa's Avatar
With all of the outputs removed, I am not measuring any DC on the output terminal. Should I re-install the three good components and re-check for this?
Old 29th October 2010, 03:04 AM   #4
Is the DC voltage on pin 3 of the upc494 remaining near 0v DC? Or is pulsing towards 5v?
Old 29th October 2010, 03:32 AM   #5
RiLoWa's Avatar
I measure it to pulse between ~81.0mV and ~87.5mV.
Old 29th October 2010, 03:46 AM   #6
Do have a scope?
Old 29th October 2010, 11:48 AM   #7
RiLoWa's Avatar
Yes
Old 29th October 2010, 11:36 PM   #8
Is the upc494 intermittently producing square wave pulses on pins 9 and 10?
Old 29th October 2010, 11:56 PM   #9
RiLoWa's Avatar
Both pins 9 & 10 look identical on the scope, but I wouldn't call it a square wave. It looks more like a dirty sine wave that apears in rhythm with the audible pulsing of the LED.
Old 30th October 2010, 01:19 AM   #10
Set the scope to 5v/div and 2ms/div. Do you see groups of pulses that deflect the trace to about 2 vertical divisions?
Alpine MRP-F200 mike49504 Car Audio 3 27th May 2010 07:29 AM
Service maanual for MRP-M350 DigiSoft Car Audio 0 17th March 2010 08:26 PM
alpine mrp m650 repair candyman122 Car Audio 6 21st November 2009 09:18 AM
Alpine MRP-M1000 argonrepublic Car Audio 2 11th August 2009 02:28 PM
ALPINE 4 Channel Amp MRP-F240 Livin Swap Meet 0 5th April 2008 06:57 PM
Page generated in 0.10685 seconds (75.66% PHP - 24.34% MySQL) with 11 queries
