#21 |
between mouser, onsemi & future elect i think i got all my parts ordered.
#22 |
i just picked up some Dow corning 340 also.
#23 |
as of now i have:
40-IRFP064N 25-IRFP260N 25-MMBTA56 25-MMBTA06 25-ES2D 25-MMBT5087L 100-10R0 still waiting for the PZTA06 & PZTA56 onsemi subs. is there anything i could do with what i got while i'm waiting? |
#24 |
You could begin replacing components. While you have the defective output transistors out of the circuit, you should be able to check the PZTA transistors to see if they're defective. They may have survived.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#25 |
so should i do it like this t30001bd schematics? or do i pull them all out ay once?
#26 |
I leave enough on each MEHSA insulator to keep the insulator in place. If you take too many off, it's sometimes difficult to get the insulator to line up with the holes in the sink when you reassemble it.
#27 |
i'm having trouble soldering the drain (pin#2) on the irfpo64n's. i have a fairly good soldering iron it's a hako 936 soldering station (900*f). any suggestions?
#28 |
Try a wider, more massive tip. It will decrease the thermal resistance and get more heat to the board.
#29 |
ok thanks. ill have to shop for some more tips.
#30 |
well, i got all my parts now but i still can't solder. i'll stop by a harbor freight tomorrow and pick up a cheap butane torch with a soldering tip.
| rockford fosgate t40001bd | bdgf2004 | Class D | 5 | 28th October 2010 06:01 AM |
| FosGate 400a4 | Gusel9 | Car Audio | 12 | 19th June 2009 04:26 AM |
| FosGate 400a4 | Gusel9 | Car Audio | 0 | 16th June 2009 04:30 PM |
| fosgate t2's | ba109296 | Swap Meet | 0 | 5th February 2006 08:37 PM |
