fosgate t40001bd bad p/s - Page 12 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 27th March 2011, 03:39 AM   #111
Was the heatsink grounded to the body of the vehicle?
Old 27th March 2011, 03:42 AM   #112
No. It was mounted on wood
Old 27th March 2011, 03:49 AM   #113
Are you sure that you don't have a bad speaker or bad wiring?
Are the center legs of the outputs shorted to the heatsink as well?
Old 27th March 2011, 03:49 AM   #114
The center legs of those 5 fets are directly shorted to the ground terminal and the ground terminal this 1 ohm from the heatsink
Old 27th March 2011, 03:53 AM   #115
Im sure that my car setup is good. I use it as a daily driver with the Memphis 4kw you helped me with.
Old 27th March 2011, 03:53 AM   #116
Were all of the screws in the board (holding the board to the bottom cover)?
It's strange that the outputs are shorted to ground but I guess that's possible if the rail switching outputs are shorted.
Old 27th March 2011, 04:00 AM   #117
Even if I disconnect the 3 jumper wires Between the 2 boards the short is still there.
Old 6th April 2011, 06:34 PM   #118
It appears as though one of my mesha strips for the power supply fets is bad. I get about 6m ohms from the back to the front pads.
Would anyone happen to know where I could find some mesha strips.
Old 4th December 2012, 12:49 PM   #119
Can someone send me schematics for a Rockford T40001BD amp to matt76.brooks at gmail dot com
I have replaced the output FETS b/c 10 out of 20 were blown. The powersupply drivers checked out ok. But, i am only getting -110V for -HV output and ~9v for the +HV side. any thoughts.
Last edited by Mooly; 4th December 2012 at 12:55 PM. Reason: Email removed for security
Old 4th December 2012, 12:54 PM   #120
Mooly's Avatar
Originally Posted by RockfordFIx View Post
Can someone send me schematics for a Rockford T40001BD amp to matt76.brooks at gmail dot com[/email]
You might be better starting a new thread and detailing the tests and checks so far performed.
Installing and using LTspice IV. From beginner to advanced.
rockford fosgate t40001bd bdgf2004 Class D 5 28th October 2010 07:01 AM
FosGate 400a4 Gusel9 Car Audio 12 19th June 2009 05:26 AM
FosGate 400a4 Gusel9 Car Audio 0 16th June 2009 05:30 PM
fosgate t2's ba109296 Swap Meet 0 5th February 2006 09:37 PM
Copyright 1999-2017 diyAudio
