fosgate t40001bd bad p/s - Page 11 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 26th March 2011, 03:01 AM   #101
Should I try this using a sine wave or music?
Old 26th March 2011, 03:27 AM   #102
You can use either. Music will be less annoying if you are using a speaker instead of a dummy load.
Old 26th March 2011, 04:11 AM   #103
after 30 min on a 4 ohm dummy load playing music it is still producing a clean output. around the corner heatsinks it is running about 110'F and on the straight a ways or along the sides of the amp it's about 100'F. neither of the 2 cooling fans ever turned on (not that i know when they're supposed to). it's about 75'F in the house. my power supply was only dropping to about 12.9v.
Old 26th March 2011, 02:53 PM   #104
It doesn't appear that there are any problems. When it blew the last set of outputs that you installed, could you find any reason for it (poorly soldered to the MEHSA insulators, etc)?
Old 26th March 2011, 03:33 PM   #105
No. I saw the distortion at the bottom of the output signal at high volume (1 ohm) and then smoke. What do you use to power up and test these huge amps?
Old 26th March 2011, 03:46 PM   #106
I rarely work on large amps now. They're simply too much trouble and too time consuming. Just repositioning them is a pain.
When I have to drive them to full power (or at least to high power, some amps are too large to drive to full power), I strap multiple supplies together and sometimes use a battery as well. It's generally not necessary to drive them to full power. If a class D amp works properly driven to clipping into a light load, it's likely OK. Generally, the only problem that causes them to fail when driven into lower loads is when there is insufficient thermal coupling between the transistors and the heatsink.
Old 26th March 2011, 05:33 PM   #107
Cool. Ill try it ln my car later.
Thank you so much.
Not only have you saved me money time and time again, I also get a feeling of success and achievment after every repair.
you are the shiznit. (That's a good thing)
Old 26th March 2011, 09:41 PM   #108
Tried it in the car... smoke. Doesn't surprise me because of the distortion I saw before. It only lasted about 10 seconds. I hope I turned it off fast enough to save the power supply
Old 26th March 2011, 09:45 PM   #109
Confirm that no center leg of any heatsink mounted transistor reads 0 ohms to the heatsink.
Old 27th March 2011, 02:27 AM   #110
It appears now that all heatsink mounted fets have shorted, power supply and outputs. Q411,12,13,14,31 center leg is 1 ohm from heatsink. I never replace any of those they were previously replaced by another person.
rockford fosgate t40001bd bdgf2004 Class D 5 28th October 2010 06:01 AM
FosGate 400a4 Gusel9 Car Audio 12 19th June 2009 04:26 AM
FosGate 400a4 Gusel9 Car Audio 0 16th June 2009 04:30 PM
fosgate t2's ba109296 Swap Meet 0 5th February 2006 08:37 PM
Copyright 1999-2017 diyAudio
