i bought a bad amp and i replaced the p/s fets with irfz44n and one channel with 540/9540. and now the amp works but the repaired channel is distorted. does anybody know what could be causing this? several yrs ago i bought a repair cd from perry babbin and it was very informing. in fact so informing that several yrs later i'm still learning. haha. i've had a fair amount of success, ive repaired bad p/s, outputs, broken boards/traces, ect... but i still have problems with the smaller things (caps, diodes, transistors, ect). if anybody could help it would be great. the pics are of a 60hz wave 1 good 1 bad. i have all te equipment needed and quite a few parts on hand.
#2 |
the pix. sorry
#3 |
Lift Dx02 and Dx04 in the defective channel. Does that allow it to produce a clean sine wave?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
i havent lifted any parts yet but i see that a transistor 2a (q216) that is connected to d204 maybe burnt.
#5 |
with the diodes out it looks good until it has a load. then it's the same
#6 |
Check Qx12 and Qx13. You need to at least lift two legs so you can check for open junctions and leakage.
#7 |
both transistors are test good
#8 |
Did you confirm that the gate resistors and the source resistors are within tolerance?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links Last edited by Perry Babin; 27th October 2010 at 03:42 AM. |
#9 |
the big resistor (r263) connected to the source of the 540 is at 700 ohm all others are at 1 ohm. what size is that? i'll have to order some.
#10 |
0.1 ohms, 2w.
While you have it out of the circuit, confirm that R261 and R262 are within tolerance.
| rockford fosgate t40001bd | bdgf2004 | Class D | 5 | 28th October 2010 06:01 AM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| rockford fosgate p4004 | mike49504 | Car Audio | 3 | 7th December 2009 09:30 PM |
| Rockford Fosgate/Mosfet | steven123654 | Car Audio | 5 | 2nd September 2009 02:13 AM |
| rockford fosgate 550x | mike49504 | Car Audio | 21 | 6th December 2008 10:26 PM |
| Page generated in 0.31800 seconds (27.04% PHP - 72.96% MySQL) with 11 queries |
