BLAUPUNKT VA4100 schematic needed BLAUPUNKT VA4100 schematic needed - diyAudio
Old 18th October 2010, 10:25 PM   #1
ultra is offline ultra
ultra's Avatar
Default BLAUPUNKT VA4100 schematic needed
For the last two days i have been trying to repair this 4 channel amp.
When i opened the cover i found out that someone has tried to repair the amp before me.
Many SMD components were re-soldered in a bad way.....
Anyway, the amp wouldn't power up so i used my lab power supply to power the secondary side (the audio channels).
All 4 channels did not draw excessive current but one of them had 30VDC on the output.
After repairing, i looked the preamp section that tested just fine.
So far, all seemed OK, except for the PWM.
Whenever i tried to power it up, the amp got started but only for a second-no excessive current drawn...just about 1.5A.
It uses the TL494 chip and i noticed that pin4 which is designated for dead time control (and maybe for protection sometimes), after one second measures 5V.So thats the cause that the amp shuts down.
I think that if i disconnect pin4 from the circuit and ground it, it will work.
If some member could produce a schematic, i could repair the amp without canceling the protection scheme.
Old 18th October 2010, 10:35 PM   #2
Perry Babin is offline Perry Babin  United States
Do you have any DC on any channel as the amp tries to power up?
Remember to check the bridging terminals, the non-bridging terminals are likely ground.
Did you have any open or out-of-tolerance emitter resistors?
Old 19th October 2010, 01:35 AM   #3
ultra's Avatar
All 4 channels are working properly. DC offset is below 50mV. Output voltage without a load is 13.6VAC before clipping (due to supply voltage limit). I cannot make power measurment as i am using a Hameg bench power supply with current limit at 0.5A per rail.
Idle current for all channels is around 50mA per rail. The amps have a fixed idle current sensed by a transistor between the Sanken power transistors.
As a ground, i use the ground plane between secondary snap capacitors.
With my oscilloscope (that also displays frequency), i can momentarily measure 38.6KHz pulses to the gates of the IRF3205s.
Output voltage of the PWM power supply is +/-31VDC but as the PWM shuts down this voltage decreases slowly.
Now, i noticed something really strange:
When i power the amp from my 13.5V/68A SMPS, it shuts down really fast.
But when i powered it from the Hameg power supply (current limited at 0.5A),
the amp stays on longer (4-5 seconds) before shutting down. So when 13.5V are current limited to 0.5A, the amp stays on LONGER.
That is how i measured voltage present at pin4 of 494-it starts around 0,3V and grows up to 4.95. Then the PWM shuts down.
Old 19th October 2010, 01:44 AM   #4
ultra's Avatar
I did not have any out-of-tolerance emitter resistors. Two 0.22R/2W resistors are used in parallel per power transistor.
The reason one channel had DC on its output was a bad soldering to the driver transistor. I did not replace any parts in the audio section.
Old 19th October 2010, 12:04 PM   #5
Can you post a photo of the inside of the amplifier?
Old 20th October 2010, 03:58 PM   #6
ultra's Avatar
I hope this pic helps...
Old 20th October 2010, 05:24 PM   #7
There is no attachment or link.
Old 20th October 2010, 07:42 PM   #8
ultra's Avatar
Sorry, i took a high resolution photo that i couldn't upload....here it is...
Old 20th October 2010, 08:53 PM   #9
What is pin 4 connected to on the board?
Old 21st October 2010, 11:31 PM   #10
ultra's Avatar
Pin 4 of TL494 is connected through a 47uF/16v and a 47K to Gnd.
It is also connected through a 4R7 to the collector of a transistor and then to another one, with several resistors around. This whole circuit ends up in a thermistor mounted on the heatsink. Although the component measures OK (12K cold), it seems that some parts are faulty and give a false alarm to the 494. This makes sense because voltage of pin 4 TL494 increased slowly up to 4.95V, forcing the Ic to have infinite dead time. And maybe thats the reason why the amp stayed on for 4-5 seconds.
What i did, was to simply remove the 4R7 and i cancel the entire thermal protection circuitry. Then i installed a Normally Open thermal switch cutting off at 75 Celsius. Now the amp works OK even with some modification.
Thank you very much Perry for your help.
BLAUPUNKT VA4100 schematic neededHide this!Advertise here!
Blaupunkt XP240+MA240 schematic/circuit plan Goetz Solid State 0 7th June 2010 02:03 PM
search schematic Blaupunkt GTA 400 Ground Zero Car Audio 16 12th April 2010 03:42 PM
Blaupunkt Nurnberg harrygrey382 Car Audio 10 25th November 2007 10:00 PM
Blaupunkt DAB54 Problem mcyates Car Audio 0 28th August 2006 12:33 PM
help BLAUPUNKT wiring bunkslug Car Audio 0 12th November 2005 02:17 PM
Copyright ©1999-2017 diyAudio
