Digital Designs Z1
Digital Designs Z1
Old 20th October 2010, 07:04 PM   #11
mike49504 is offline mike49504  United States
Both of them are 13.65 volts
Old 20th October 2010, 07:06 PM   #12
Perry Babin is offline Perry Babin  United States
Are the VGS and Vdoub pins connected by any components?
Old 20th October 2010, 07:23 PM   #13
Doesnt appear to be connected through components
Old 20th October 2010, 08:43 PM   #14
Use your multimeter to see if you read 0 ohms between pin 13 and any other components on the board. There could be traces underneath that you can't see.
Old 20th October 2010, 09:47 PM   #15
Ok they both go to 1 end of a resistor then the resistor connects to a C1027 transsistor.
Old 20th October 2010, 09:48 PM   #16
Which leg of the 1027?
Are there any Zener diodes connected to the 1027? If so, which leg?
Old 20th October 2010, 10:04 PM   #17
Ok in the circuit the Vgs and the Vdoub connect to a resistor.
I found that the wrong value resistor was in the board its suppose to be a 2.2 ohm (red,red,gold,gold) and there was a 2.2K ohm resistor there (red,red,red,gold) The resistor connects to leg 1 of the 1027
Could that be the cause Of no supply voltage?
Old 20th October 2010, 10:07 PM   #18
If it's in series with the line feeding pin 13, yes.
Old 20th October 2010, 10:12 PM   #19
Ok the battery - goes to a zener diode (1n4745) then the other side of the diode goes to a disk cap (104) and then goes to the 3rd leg of the 1027.
Diode checks fine I will replace the disk cap ,1027, and the resistor and see what i come up with.
Old 20th October 2010, 11:39 PM   #20
Perry,
Thank you for all your help I greatly appericate it.
Amp is up and running
Digital Designs Z1Hide this!Advertise here!
Digital Designs Z2 teen Class D 4 6th October 2010 06:59 AM
blown Digital Designs M1 mono amp djQUAN Car Audio 10 11th January 2008 12:48 AM
Digital tube designs? martinab2 Tubes / Valves 2 27th March 2005 10:30 PM
Stryke 15 VS Digital Designs 9515 subwoofer pkgum Subwoofers 2 29th December 2001 11:09 PM
Digital preamp designs? Helix Digital Source 11 13th September 2001 12:14 PM
