I recieved this Audio Q amp in for repair. The power supply fets are missing but i believe the orginals were DFP50N06's with 47 ohm gate resistors .
Is there a good sub to The DFP50N06's?? Second question is The rectifiers are missing out of the amp beside 1 which is a FMG22U will the FMG22R and FMG22S be good replacements?? |
#2 |
I didn't find a datasheet for that FET but from the part number, I'd think a Z44 would be a good sub.
Does the rectifier have any diode symbols on its face? If so, which way are they facing?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
The fmg22u arrows are pointing like this: -->+-->+
Also i may have another problem It appears that parts may be missing off the power supply driver board. Do you have any pics of the board by chance? |
#4 |
That's a doubler. The FEP16DTD should be a good sub.
I'm not familiar with the amp. Post a photo of the driver board. I'll see if I have anything on it.
#5 |
I found a Brand new board in my collection of stuff Only difference between them is the board out of the amp has a 393 on it and the new board i found has a 293 on it Will that work or do i need to change the ic?
#6 |
The 293 and the 393 are essentially the same.
#7 |
2 other things real quick.
All of the rectifiers are suppose to be the FMG22U's correct? Can i switch the 3228's (drivers ) to 2383's? Since the drivers in this amp are missing legs |
#8 |
In amps that use doublers, all rectifiers are generally the same.
If these are the transistors you asked about previously, they should be good subs.
#9 |
How do i figure out what order the drivers go in.
C3228 ad thw A1275 |
#10 |
The PNP drivers will have their collectors connected to ground.
| FS : Antique Sound Labs AQ-1003 PCB for DIY (INTEGRATED AMP EL34 PP) | ANALOG GUY | Swap Meet | 7 | 21st April 2012 12:23 AM |
| Power-Save 1200 | davidlzimmer | Everything Else | 0 | 27th December 2006 09:39 PM |
| Antique SoundLab AQ-1003 | cfamily | Car Audio | 1 | 15th July 2006 02:27 AM |
| P.G. Tantrum 1200.1 Circuit | BBB1 | Car Audio | 0 | 31st October 2004 05:35 PM |
| DeWald M-1200 | jorge1 | Tubes / Valves | 0 | 31st October 2004 12:39 AM |
| Page generated in 0.11028 seconds (77.32% PHP - 22.68% MySQL) with 11 queries |
