Im rebuilding the power supply in this amp.
It is using C3228 drivers in the supply . Will the C2383 work in its place? |
#2 |
The sub should work.
Are you sure that they have failed? The NPN driver transistors very rarely fail.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
They didnt fail the problem is someone tryed working on this amp and broke 1 of the legs off the 3228.
#4 |
Hello I have a BXI2610D amplifier and the driver transistors went out causing the IRFP064N mosfets to blow in the power supply. I replaced the drivers with NTE 31 and NTE 32. Then I replaced the mosfets. The amp worked fine for a while and then the same issue occured. Could the PWM circuit be failing causing the rest of my problems to reoccur? I would like to fix this amp once and for all being as its a great amp. Any input would be greatly appreciated. Thanks.
#5 |
In my honest opinion. Never use NTE parts in amps they are usually expensive and alot of amps do not like NTE parts..
When you order the power supply fets also order BD139's and BD140's for replacements for the drivers.. Ive used them in alot of amps and so has Perry and never had a problem with them. Also before u order the parts make sure u also check the gate resistors for the power supply fets and make sure they are within tolorance.. |
#6 |
Thanks mike. I already picked up the NTE parts at a local parts store but i will return them to get the ones you stated. I haven't checked the gate resistors but will do so. Can you tell me what value they should be? I don't have an oscilloscope yet so i have to get one of those too. I want to make sure the waveform coming from the drivers is correct before putting in all of the FETs. Thanks again. Im just learning electronics so this is my first project and it was fixed once so i know i can do it again
#7 |
I am looking at BD139 and BD140. They are sold in matced sets of two each or I could purchase them individually. Does it matter if they are matched?
#8 |
I cant remember right off hand what the value of the gate resistors are what are the numbers on them?
#9 |
The drivers don't have to match. Matching is required for parallel components. The drivers are not in a parallel configuration.
#10 |
I have all the fets removed and got the BD 139 and BD 140 drivers in place. The voltage at each gate pad reads +4.15 and -8.8 volts. Is this correct? I will post pics of the waveform by the weekend if I can get a scope. Also should the zener diodes at each end of the mosfet banks be replaced? Not sure if they are good but i didn't replace them last time and the amp worked flawlessly until the power supply melted down again.
| Hifonics Brutus BXI 2008D | mike49504 | Car Audio | 13 | 17th February 2012 04:21 AM |
| HIFONICS bxi 1606d | timwebb | Car Audio | 40 | 16th September 2010 11:10 PM |
| Hifonics Brutus BXi 1606d parts | Bertje | Car Audio | 2 | 3rd June 2010 03:33 PM |
| Hifonics Bxi 1606d Please Help | dmeche | Class D | 3 | 25th July 2009 07:15 PM |
| hifonics BXi 1606D burnt resistors??? | gadgeteer123 | Class D | 7 | 30th June 2009 08:55 PM |
| Page generated in 0.09943 seconds (76.46% PHP - 23.54% MySQL) with 11 queries |
