#11 |
I just tested it for audio output. I'm using my computer for source signal and the amp is bridged into an 8 Ohm speaker. It does produce sound. The music is clearly audible and it had no problem making power. I wouldn't exactly call it clean. It has a hiss [similar to white noise] at low volume and no volume with or without source connected I don't recall it being affected by the gain control. It probably wouldn't be an issue in my application, but it does have the potential to run a set of seperates up front sometime down the road. The hiss would drive me nuts in that application. I'm excited to hear it play and grateful for the help getting it to this point. Thanks all. How complicated is it to diagnose the hiss, or should I replace the known defective components at this point and then continue the diagnosis as they may be causing it?
Alan |
#12 |
Do you have an oscilloscope?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#13 |
no, but i may have access to one. I will need to see what i can do. Anything I can do without one? Thanks - Alan
#14 |
It would be easier if you had a scope.
| Old School Orion 2150 gx.I must repair this amp | spooney | Car Audio | 99 | 21st August 2010 02:53 PM |
| Repair Help on Orion 2500d | wccoug21 | Car Audio | 28 | 13th January 2010 03:25 AM |
| Orion 280GX amp repair | thegmann | Car Audio | 11 | 11th April 2008 05:44 PM |
| Orion 222 SX repair questions | grjr | Car Audio | 11 | 22nd December 2007 07:32 AM |
| Orion NT 200 vs Orion 2150 SX | Clipped | Car Audio | 3 | 12th June 2007 01:55 PM |
