Hey guys, i thought i would start by attempting to fix the jl 300/4 but that might be too advanced for me right now. I figured id start with something that is less complicated. I had a directed d800 that was popping the amp fuses, not the inline ones. So i took the amp apart and noticed there was a irfz48n that was shorted out (see pic) Anyway i replaced all 4 of them, and i powered the amp on it worked for a few minutes but i noticed the ground wire was getting really hot. So i took it off checked everything out, everything looked ok. But then when i hooked the amp back up it kept popping the inline fuses not the amps fuses. Any ideas ?
![]() Thanks -Rob Last edited by DcMaN; 1st September 2010 at 07:00 PM. |
#2 |
Can you post a photo of the inside of the amp?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Ill post a picture as soon as i get home from work.
-Rob |
#4 |
#5 |
Remove the rectifiers. Does the amp blow the fuse (15 amp fuse suggested below).
Insert a 15 amp fuse in the B+ line and clamp all remaining components tightly to the heatsink before applying power.
#6 |
so remove those 4 that i just put in (the ones with out the heatsink on)?
#7 |
The Z48s are the power supply FETs. The rectifiers are near the large capacitors (possibly fully encapsulated -- difficult to see in the photo).
The heatsink is the large aluminum outer shell. The missing parts in the photo are clamps.
#8 |
they are indeed fully encapsulated im removing them now ill let you know in a few min
#9 |
ok, so after removing the rectifiers, the inline fuse doesnt blow, but it puts my regulated powersupply into protect.
#10 |
What's the current rating of the power supply?
| Keep Blowing Fuses | Whiting | Tubes / Valves | 9 | 11th September 2008 09:44 PM |
| Transistors that replaced Nuvistors | mmerig | Parts | 3 | 8th June 2005 02:10 AM |
| Blowing fuses | balance | Tubes / Valves | 2 | 5th March 2005 02:16 AM |
| blowing fuses | homegrown45167 | Car Audio | 2 | 22nd October 2004 12:16 PM |
| The Fuses Just Keep Blowing | raffir | Chip Amps | 19 | 22nd June 2003 03:49 AM |
| Page generated in 0.10720 seconds (78.68% PHP - 21.32% MySQL) with 10 queries |
