Go Back   Home > Forums > General Interest > Car Audio
Old 30th August 2010, 01:57 AM   #1
Default American Bass CX-1200-D
This amp is using RFP70N06's with 47 ohm gate resistors .
Is there a good sub for the RFP70N06's ?
Old 30th August 2010, 03:16 AM   #2
irfz48 should work fine
Old 30th August 2010, 04:12 AM   #3
Since the RFP70N06s are readily available, I'm assuming that you want to use what you have on hand. Post what you have.
Old 30th August 2010, 04:29 AM   #4
Ill just order the originals from mouser .
Next question is The power supply in this amp was totally shot.
The outputs all test good . Does the class d board go bad if the power supply burnt up or generaly only if the outputs failed?
The class D board in this amp I believe is unrepairable if it goes bad.
Old 30th August 2010, 04:58 AM   #5
It's rare for driver boards to fail in most amps unless the transistors they're driving fail. You can install a couple of FETs to power it up to see if it produces clean output.
Old 31st August 2010, 07:51 PM   #6
Ok I replaced the power supply fets with the originals. Also replaced the drivers and gate resistors And a couple caps and a few other resistors in the supply.
If i try to power the amp up no light come on but i can hear the relay kick on.
Amp has 1.0 volts on leg 1 of the power supply fet and 13.5 on middle leg.
AMp does not produce rail or regulated voltage.
Wondering where i go from here?
Old 31st August 2010, 09:58 PM   #7
Ok i dont get this amp.
In the Pics there is a spot for a 47 ohm resistor right now i have it removed.
As soon as i apply power and ground no remote the resistor smokes within 1 sec
I pulled the driver boards for the power supply and it still smokes within a sec.
1 side of the resistor connects to a 47 uf 25 volts cap
the other side connects first to the 22 ohms resistor in the pic then goes to a diode which tests fine then goes to the relay.
If i measure across tthe pads of the 477 ohm resistor i get 13.92 volts on the pads.
Wondering what might cause this resistor to smoke within 1 sec?
Old 31st August 2010, 10:13 PM   #8
Photos didn't load.
Old 31st August 2010, 10:26 PM   #9
Duh
Heres the pics
Old 31st August 2010, 11:00 PM   #10
Are there any solder bridges?
Are any of the capacitors connected to the resistor shorted?
FS: Dayton sub 1200, Eminence sub, Seas mid-bass, HiVi, ATD, Axon ccz Swap Meet 3 17th August 2010 08:54 PM
3a Triphonic 1200 sub-bass schematics MontrealMaggieB Subwoofers 1 1st July 2008 11:32 PM
Problem with CX 2310 Moondog55 Multi-Way 1 21st April 2008 12:40 AM
Cunningham CX 301A Trout Tubes / Valves 11 11th December 2004 07:43 AM
Page generated in 0.10069 seconds (76.46% PHP - 23.54% MySQL) with 11 queries
