ppi pcx 1250 problem
Old 20th August 2010, 02:18 PM   #1
3nCod3R is offline 3nCod3R  United States
Default ppi pcx 1250 problem
The amp stays in standby all the time drawing almost an amp. Any ideas ?
Old 20th August 2010, 05:33 PM   #2
Perry Babin is offline Perry Babin  United States
Have you checked the output transistors?
Old 20th August 2010, 05:54 PM   #3
I have not checked anything on the board yet, just a visual inspection that has revealed a hot resistor (R34) which feeds one of the transistors. It reads 80 ohms, the others in the same bank read 18 ohms. The next question is how to remove the board from the case, it seems they must have a jig to assemble/disassemble this unit. All the transistors are clipped in to a rail on both sides of the board.
Old 20th August 2010, 06:19 PM   #4
Read THIS.
You can probably check the outputs without removing the clamps.
What transistor (part number on face of transistor) is that resistor connected to?
Old 20th August 2010, 06:35 PM   #5
Got the clamp off, works well when you know the trick, thanks. The part number on the transistor is RFP70N06, and it is cracked wide open.
Old 20th August 2010, 07:13 PM   #6
You'll need to replace all of the RFP70N06s. You still need to check the output transistors.
Old 18th October 2010, 05:22 PM   #7
Default update on pcx 1250 current draw when off
Just an update for anyone who has this type of problem in the future.....replaced all of the mosfets for the power supply and the unit functions normally. There were several that were shorted, and since they are in parallel, it was causing voltage to drop on the gate resistors. Thanks for the help !
ppi pcx 1250 problemHide this!Advertise here!
repairing PPI PCX-2200 redblaze Car Audio 20 27th December 2013 12:19 AM
PPI PCX-2200 took it toll on subs skooter Car Audio 7 26th November 2007 03:32 AM
PPI PCX-2200 connectors needed skooter Car Audio 2 25th November 2007 03:31 AM
PPI PCX-2200 manual needed skooter Car Audio 4 24th November 2007 01:27 PM
burnt resistors on PPI PCX-1250 cutlass1991 Car Audio 9 19th September 2006 11:38 PM
Copyright ©1999-2017 diyAudio
