hi
am working an a amp sound stream xta720.4,it comes on and stays in to protection mode.somebody had already try to repair this amp befor i get it.i test for shots and leaks i did not find any so i took some voltage test pwm ic 1=.5 2=4.9 3=4.8 4=.1 5=1.5 6=3.4 7=.0 8=15.8 9=.0 10=.0 11=15.7 12=15.1 13=4.9 14=4.9 15-4.9 16=12.1 from g terminal to center of irfz44s=15.0 )))))))))))))))))))))))first leg=.0 )))))))))))))))))))))))third leg=.0 i change the pwm ic and the 4558d with no change any kind of help will be good thanks |
#2 |
Have you checked the outputs to see if any are shorted?
If there are no shorted outputs, get the schematic diagram from SoundStream and email me a copy of it. babin_perry@yahoo.com
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
i did not get the schematic but i am still tryin to fix this amp
now after i unsolder the two legs of one of the input transformer the amp will not go into protect again befor i did that the voltage on the input of both transforms is 15v and the output is 6.5v i dont no y is that.am thinking of leaving this amp with one side working any ideas??/????????? i also change the transformer but still no change Last edited by ian33; 27th August 2010 at 03:35 AM. |
#4 |
Did you try to get the schematic diagram for it?
#5 |
i did not get the schematic after days tryin to fix this amp i started to switch parts i change all the mosfet in the power supply and three small transistor witch i think is use for the buffer now the amp works ok.i think the transistors only break down when voltage is apply to them cause they tested ok with my meter
| Sound Stream SA245 repair help | grjr | Car Audio | 4 | 29th December 2008 07:25 AM |
| How to protect sound card during amp measurements? | okapi | Everything Else | 13 | 2nd September 2008 03:06 PM |
| Sound Stream Mc-245, No Power!..help! | JT_mechanic | Solid State | 0 | 27th May 2008 10:37 PM |
| sounds stream? | subarusteve | Car Audio | 0 | 1st May 2005 01:53 AM |
| sound stream any good? | 1needforspeed | Car Audio | 6 | 20th March 2005 02:09 PM |
| Page generated in 0.08823 seconds (75.16% PHP - 24.84% MySQL) with 10 queries |
