Go Back   Home > Forums > General Interest > Car Audio
Old 23rd August 2010, 12:34 AM   #11
With only the 640s in the circuit, it is likely producing DC which is causing it to go into protection. With no outputs, it may power up normally.
Old 23rd August 2010, 01:34 AM   #12
with no outputs in the amp it powers up fine.
If i put 9640 and 640's in the amp it draws excessive current .
I checked the outputs all test good.
From all of the dircted amps ive worked on this one is the one from hell.
All the other directed amps ive worked on the 9640's were closet to the power supply fets then the 640's were near the rca jacks.
it seems like all pads are connected together in this amp for some reason.
Any thoughts?
Old 23rd August 2010, 02:27 AM   #13
Which pads are connected together?
Old 23rd August 2010, 02:45 AM   #14
i was getting strange readings between the pads i switched batteries in my meter now its measuring right.
With no outputs in the amp it powers up and idles fine.
On the output pads the reading i get are
1 banks of outputs
Leg1: -68.2
Leg2:0
Leg3:- 71.3
2nd bank
Leg1:72.1
Leg2:0
Leg3 70.1
So that appears to look good.
As soon as i put the outputs back in it it draws excessive current.
So Do you know what they are using for the drivers for the outputs?
Old 23rd August 2010, 03:11 AM   #15
Ok the 2 drivers circled are defective.
They are marked.
DK QY
AG QQ
Is there a good sub for theese??
Old 23rd August 2010, 03:59 PM   #16
See if the 2SA1797 and the 2SC4672 appear to be the same transistors.
Old 23rd August 2010, 09:01 PM   #17
Im just wondering i have some other transistors that are new but i lost the packaging on them to tell me what they are.
they are marked
DY
209
CY
209
Wondering if theese will work in this amp or not??
Old 24th August 2010, 12:23 AM   #18
The SMD Code Book
Use this page to find the part numbers. Compare the dimensions in the datasheet to the device to confirm that they are the correct parts.
Directed 1100 D mike49504 Car Audio 4 2nd August 2010 05:03 AM
Directed 750 D mike49504 Car Audio 35 23rd July 2010 04:51 AM
Directed D1200 mike49504 Car Audio 3 6th July 2010 01:34 AM
Directed D800 mike49504 Car Audio 8 21st June 2010 02:50 AM
Directed D2400 mike49504 Car Audio 10 20th April 2010 04:52 AM
Page generated in 0.09632 seconds (75.41% PHP - 24.59% MySQL) with 11 queries
