Go Back   Home > Forums > General Interest > Car Audio
Old 16th August 2010, 09:12 PM   #1
FireII is offline FireII  United States
Default Boston GT-42, info needed
Customer brought in a Boston GT-42, he said that when he powered his amp OFF sparks and smoke came about, I'm kinda puzzled as to what could have caused this to happen when powering an amp off except for pure coincedence. Anyways, every psfet is burned beyond recognition and there is some damage to the board but I believe it can be repaired, I've yet to determind the cause of the ps failure, to both power supplies but I need to know what I can replace the psfets with to get the amp to run. Any help would be appriciated.
Thanks,
Greg
Old 17th August 2010, 12:27 AM   #2
I also need to know the part numbers for the ps drivers coming off of the sg3525 so that I can pull a datasheet on them, they are not legible.
Thanks,
Greg
Old 17th August 2010, 03:14 PM   #3
I don't have any information on this amp. Have you tried cleaning the faces of the transistors (acetone) and trying to piece together the part numbers from several to determine the part number?
Applying heatsink compound and then removing the excess can often help bring out the markings.
If you can post a photo of the power supply section of the amp, it may be helpful.
Old 22nd August 2010, 05:32 PM   #4
I was able to make out a PS FET, they are P60NF06, which are available, the gate resistors are 56ohm. I still cannot make out the drivers, all four of which are toast as well. I've included a picture as requested.
Old 22nd August 2010, 05:50 PM   #5
Are the 4 surface mount transistors on the corner of the board the driver transistors?
Can you read any of the numbers on the face of them?
Old 22nd August 2010, 05:55 PM   #6
Yes, those are the drivers. On only one of them can I see, what looks like, BL 534, but I'm not 100%.
Old 22nd August 2010, 05:57 PM   #7
Does the center leg on 2 of them go to ground and the center leg on the other two go to B+?
Old 22nd August 2010, 07:10 PM   #8
I'll have to pull them to find out.
Old 22nd August 2010, 07:23 PM   #9
You don't have to pull them. Use your multimeter.
Old 22nd August 2010, 07:34 PM   #10
Perry,
Yes, this is correct.
Seeking Info on Boston Acoustics A150 big314mp Multi-Way 0 23rd December 2009 11:42 PM
Boston Acoustics 8" woofer needed for T830 todd12345 Multi-Way 4 7th July 2007 07:16 AM
DIY AMPLIFIER KIT -- > class d? need info!! JinMTVT Solid State 6 30th April 2006 06:00 PM
NAD 3020A -info and reapir thread> ZuMbAiU Solid State 24 28th February 2006 04:18 PM
0-42 0-42, 1500VA Toroidals richie00boy Group Buys 10 23rd November 2004 11:24 PM
Page generated in 0.09906 seconds (84.46% PHP - 15.54% MySQL) with 11 queries
