Need a little insight with this amp. I see no activity from the 494, what I don't see is the typical LM393 comparator next to it for shutdown. It has a mess of transistors around it, maybe I need to focus on those.
Originally one of the output gate drivers had defective solder joints on all 3 pins. I soldered that back in, but still no output. |
#2 |
Without the pcb mounted in the metal heatsink a gnd is floating, that is why no start up. Next time I won't accept an amp that has been taken apart, unless I get all the hardware with it.
I still have no rail voltages, will have to check all connections now. |
| Eclipse 3121 | spooney | Car Audio | 0 | 23rd November 2007 12:37 PM |
| CD8053 Eclipse | corradolvr | Car Audio | 4 | 8th September 2007 06:14 PM |
| eclipse problem | mike49504 | Car Audio | 2 | 16th April 2007 07:35 PM |
| Eclipse | Brian Donaldson | The Lounge | 5 | 28th October 2004 08:32 PM |
| Eclipse? | Larr_e_boy | Multi-Way | 0 | 7th June 2001 02:41 PM |
