Go Back   Home > Forums > General Interest > Car Audio
Old 11th August 2010, 11:17 PM   #1
Jexx is offline Jexx  United States
Send a message via MSN to Jexx
Default Lubricatoin for Mechanical Bits?
I have a JVC El Kameleon (the CD player with the face that goes all black when turned off) that is fully motorized. The unit is getting old (built circa 1999!), but still functions wonderfully minus one thing: the face.
The motorized face works well, but every once in a while will get hung up or jammed and I have to tap it with my hand etc. so the various flaps can finish opening/closing/receding etc.
I'm quite certain it's just an issue of lubricating the mechanical bits since it gets jammed 1 out of every 5 times, and it takes very little effort to unjam the face (really, a tap is all it needs).
So my question: where can I get a good lubricant for the various mechanisms? Is there some sort of household product I could use?
Old 12th August 2010, 12:43 AM   #2
Three classes of product come to mind.
(1)There is a lanolin based lubricant that is good. The down-side is that your equipment may smell like a lambs wool!
(2) Also you might try the teflon based products. Probably available widely but pushbike shops will certainly stock it for chain lubrication.
(3) And I guess the obvious one is the lubricant they use on sewing machines. Some sort of light machine oil.
I expect a lot of others too.
Cheers, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 12th August 2010, 01:37 AM   #3
theAnonymous1's Avatar
You don't want to use a liquid lube, you need something with substance.
Some Super Lube gel should do the trick....
Grease | Oil | Synthetic Lubricants
... or some white grease....
http://www3.towerhobbies.com/cgi-bin...&I=LXKR90&P=FR
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 12th August 2010, 04:27 AM   #4
Generally, if a mechanism is sticking, it's bent, has something in the gears (piece of sand or similar) or has a cracked gear.
Old 19th August 2010, 06:45 AM   #5
finbar is offline finbar  Canada
Any lube that stays wet will accumulate dust and grit, forming a grinding paste.
Old 25th August 2010, 01:56 AM   #6
Thanks a ton, everyone.
Every single post here was helpful. I tried a bit of sewing machine grease and that actually seems to have fixed the problem, and as finbar suggested, it will likely accumulate dust etc., so I'm going to get something more professional/appropriate, such as white grease (exactly what I was looking for but didn't know the name). I also played a bit with the mechanical bits to check for bends, and I think one of the lower arms was bent slightly. So it's working MUCH better now.
Thanks again! This is why I love this forum.
mechanical hum Bill*B Tubes / Valves 4 30th May 2007 09:42 PM
24 bits DAC with 16 bits guytou Digital Source 2 9th August 2005 10:40 PM
Mechanical ear purplepeople Everything Else 1 5th February 2005 02:40 PM
Mechanical Linkwitz-Greiner angel Multi-Way 0 13th April 2004 07:33 PM
New forum/-Mechanical Magura Everything Else 0 29th March 2004 01:21 AM
Page generated in 0.07677 seconds (83.46% PHP - 16.54% MySQL) with 10 queries
