Go Back   Home > Forums > General Interest > Car Audio
Old 17th August 2010, 08:28 PM   #11
Send a message via MSN to NBBN_amplifiers
Default Some short in the audio output stage
I've been working with car audio AMPs for a long time. Looking at your problem it seems to me that you have some output stage mosfet or bipolar in short circuit.
Try to unplug the power supply and measure resistance in the output of the transistors. I assume that someone may be bad.
Since the circuit is generating DC to the other side of the toroid this is what may be happening...
Nickel
Old 19th August 2010, 07:58 PM   #12
grjr is offline grjr  United States
Just to update the thread, I reconnected the preamp to the discrete amplifier and everything seems to be working good. Haven't ordered new parts to finish up the amplifier yet but I will do that soon. Still wondering if the waveform at the base of the D44H11 switching transistors is fine. Maybe if someone has an orion 222 sx lying around they could chime in. Thanks for your help Perry, it is very much appreciated
Old 20th August 2010, 04:21 PM   #13
I would expect the waveform to be more flat across the top. It may be better as the pulse width increases. Try decreasing the DC power supply voltage. That will cause the pulse width to increase.
Simple TL594/single MOSFET offline SMPS EWorkshop1708 Power Supplies 11 25th August 2010 12:30 PM
Mixed signals??? genmin Car Audio 4 12th February 2009 06:58 PM
Question on efficiency if PWM amps and PS noah katz Class D 33 3rd July 2006 07:26 AM
Quick question - common ground on stereo signals swedish_lunacy Analog Line Level 2 4th May 2006 05:17 AM
Degaussing signals fmak Parts 2 29th April 2006 03:47 PM
Page generated in 0.06387 seconds (81.20% PHP - 18.80% MySQL) with 10 queries
