ok i got this amp in and i got ut to power up but one of the channels is making the sub osc what would cause this?
#2 |
High or low frequency oscillation?
Is the oscillation visible on the speaker terminals? Does it do it with no RCAs plugged in?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
it makes a pop then osc low i pulled the two burn output transistors but i still get a protect light when i put them in
#4 |
#5 |
yea i even took the driver card out and it still does it
#6 |
Is the power supply pulsing on and off?
#7 |
no it stays on i checked the driver signal and its showing a distorted signal like its osc to fast i changed the drive transistors and it still does it and pin 5 on the 494 is distorted
#8 |
How is the signal on pin 5 distorted?
#9 |
there are small pules on the sawtooth wave
#10 |
Remove Q41 on the power supply driver board to see if it makes a difference.
| BD139-16 & BD140-16? Anyone use these transistors? | grhughes | Parts | 35 | 28th April 2010 02:21 PM |
| Classic 16.0 | Lowrider | Tubes / Valves | 38 | 6th August 2008 08:15 AM |
| mj11015/16 | smokingmachine | Solid State | 21 | 26th February 2006 08:51 PM |
| Page generated in 0.08939 seconds (74.96% PHP - 25.04% MySQL) with 10 queries |
