diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Repairing Rockford fosgate punch 40X2 channel help (http://www.diyaudio.com/forums/car-audio/171598-repairing-rockford-fosgate-punch-40x2-channel-help.html)
chipper 9th August 2010 04:52 PM
I wanted to try and repair a channel on a Rockford amp ive had sitting for months it works great but one side gives me 27 volts. Maybe some mosfets shorted out? Is it possible to buy some new mosfets and just slap em in and will function again? Or will the problem be present again? Could there be anything else short? I measured the big resistors and they read 0.01 is that good? Sorry for all the questions,,,still trying to learn. Thanks
FireII 9th August 2010 07:20 PM
Can you be more specific when you say "one side gives me 27 volts" ?
brandes.cm 9th August 2010 07:36 PM
Typically you would check the gate resistors and drive transistors prior to powering it up after fet replacement. Clamp things to the heatsink and fuse the B+ line to help preserve the new fets in case you missed something.
chipper 9th August 2010 07:36 PM
I suppose it's 'rail voltage' I measured it with a dvm. Before that it was pushing the speaker out. It's the left channel that's down. What shout I look for on this??
FireII 9th August 2010 07:42 PM
Set your meter to diode check, check the voltage drop between all three legs of your output transistors, meaning place one lead on leg 1 and the other on leg 2, then check 1 and 3, then check 2 and 3(especially). If you get anything near .0v then the transistor is toast. If you post a picture of the amp we can tell you which transistors are your out puts, or if Perry chimes in he can prolly tell you off the top of his head.
brandes.cm 9th August 2010 07:45 PM
Grab the 40_2 schematic from my site, it should be close to what you have.
https://sites.google.com/site/brandescm/home/projects
Outputs are labelled Q115, Q119, Q215, Q219
chipper 9th August 2010 08:19 PM
Yes I already did that and I got on diode check (IRF9540) .004 according to my meter and it was making a beeping
noise indicating it was shorted and I got for (IRF540) legs 1&2 (gate to drain) .528. Gate to source i got .075.
chipper 9th August 2010 08:29 PM
Can you tell me which ones are the driver transistors? Are they surface mount? I checked the small surface mount resistors and i got 11 ohms for R150 and 12 ohms for R152 they both have 100 marked in them. Are these 10 ohm or 100 resistors? Thanks for the help!
mike49504 9th August 2010 08:34 PM
I would replace all the output transistors for the left channel. Also check the large emitter resistors check if there is and discoloration on them.And also check the driver transistors for the left channel outputs.
If all check good replace the outputs and turn the bias pot fully counterclockwise.
Replace the IRF9540's and 540s's with the same part or switch to IRF540A
(A) as the suffix.
The 540N and 9540N's may give you problems as some of the rockford amps ive worked on didnt like the 540n's and 9540n's
Hope this helps
mike49504 9th August 2010 08:37 PM
They are surface mount transistors for the drivers They are usually marked 1a and 2a set your meter to diode check and test them the same way as you did the outputs. Make sure you pull the bad outputs from the board before u test them.
Also the resistors you tested marked 100 are 10 ohm resistors if you have 11 ohms on 1 and 12 ohms on the other they should be fine
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
