Alpine 3527S Repair
Alpine 3527S Repair
Old 9th August 2010, 05:33 AM   #21
myk777 is offline myk777  United States
Originally Posted by Perry Babin View Post
With no RCAs plugged in, what's the resistance from the RCA shield to the non-bridging speaker terminals?
In the MegaOhm range like 5 or 6 MOhms, seemed the same to all speaker terminals regardless of bridging ones or not.
Old 9th August 2010, 05:44 AM   #22
Perry Babin is offline Perry Babin  United States
I think that the resistance from the RCA input shield to the non-bridging terminals should be near 0 ohms. Is the resistance between all of the RCA shields near 0 ohms?
Old 9th August 2010, 05:56 AM   #23
No, they all seem seperated they're also in the MOhm range. The meter keeps changing in one direction when I measure them, same as when I measured between the shield and the speaker terminal almost like they are ramping up?
I think I'll pull the board out again and have a closer look at the back side again.
Mike
Old 9th August 2010, 06:09 AM   #24
Some Alpine amps have balanced inputs and some have a common shield ground. If none of the RCA shields are connected (0 ohms), then there shouldn't be a connection from the shield to the non-bridging speaker terminals.
The secondary center-tap of the power transformer should be directly connected to the non-bridging speaker terminals, no matter the input RCA shield configuration.
When you pull the board, look for cracks and bad solder connections.
Old 9th August 2010, 07:42 PM   #25
Well, I've scoured the thing over and over and just can't find anything that looks wrong. I might just install that 330pf ceramic capacitor between B- and one of the speaker leads as it seems to fix the idle current issue and see what happens long term, other than that I'm out of ideas. Perry, you don't happen to have a schematic for this one or possibly one of its close siblings do you?
Old 10th August 2010, 01:56 AM   #26
I have one for the 3550 which may be somewhat similar. Email me if you want it.
babin_perry@yahoo.com
Old 17th August 2010, 06:36 AM   #27
Update:
Well, right or wrong I ended up soldering that 330pf cap in between the B- and one of the speaker output terminals, stuck the amp back in the truck and it's been working fine for the last week, sounds great as usual.
Alpine 3527S RepairHide this!Advertise here!
Alpine CDA 7969R Repair JonFennell Car Audio 1 5th March 2010 11:18 PM
alpine mrp m650 repair candyman122 Car Audio 6 21st November 2009 09:18 AM
Alpine mrd-m501 Repair dj_square- Car Audio 2 31st August 2009 05:15 AM
Alpine CDA-7995 Repair Q. ACraig Car Audio 6 14th May 2009 01:57 PM
Old School Alpine repair Nismoron Car Audio 9 21st December 2008 12:38 AM
