Go Back   Home > Forums > General Interest > Car Audio
Old 7th August 2010, 10:12 AM   #1
marko is offline marko  United Kingdom
Default Boltar gen X op-amp.
Hi all, just fitted new rail caps in my Boltar project, they had literally failed through vibration! anyway i replaced them and on rebuild i noticed some issues with the pre-amp module, op amp 2068d for r/l in had disintigrated it also took out a small cap which i have already replaced.
rest of amp seams ok and drawing 1.5amp on idle
any ideas where i may find a suitable replacement? ebay brings nothing up on the 2068d
Mark.
Old 7th August 2010, 05:55 PM   #2
It's an NJM2068D.
Old 7th August 2010, 06:00 PM   #3
any idea why it would fail?
would this be ok?
LINK
Old 8th August 2010, 12:50 AM   #4
It's virtually impossible to determine why it failed.
It appears to be the correct part but I've never seen one with a DD suffix.
Old 17th August 2010, 04:03 PM   #5
so i replaced the opamp, connected up and the small cap in the preamp module i replaced started to smoke immediately and went bang in a big way! no idea why this small cap would fail again? can inserting the POS card wrong do this?
Old 17th August 2010, 05:10 PM   #6
Removed the bad cap first off.
have everything clamped tightly and everything soldered in place besides the cap that blew.
Power up the amp and set meter to volts and check the voltage across the pads for the cap.
what is the voltage across the pads??
what voltage rating does the cap have?
Old 17th August 2010, 05:14 PM   #7
good call, i'll go and do that and report back
think the cap is a 20v 47uf..
Old 17th August 2010, 05:33 PM   #8
i think i know why it went pop (again), it had 48v in there, i swapped the POS card around and 10ish volts appeared. there are 4 ways in which the POS card can fit and only 2 are the correct way!
EDIT- replaced the cap, no explosions but the amp is only pulling 0.14v on idle and has no output. think the amp is struggling to turn on
Old 17th August 2010, 06:02 PM   #9
think the cap is a 25v 47uf..
Old 17th August 2010, 09:36 PM   #10
0.14v where?
POS card?
Can you post a few photos of the inside of the amp?
Sonic Impact Gen 2 T-Amp ? AdamThorne Class D 150 16th September 2008 03:58 PM
boltar generation x old school badcompany Car Audio 2 27th July 2008 12:13 AM
Hifonics Boltar VIII Problem vypr Car Audio 22 19th February 2008 03:46 AM
Sonic Impact Gen 2 T-Amp gvr4ever Class D 2 10th October 2007 07:31 AM
Page generated in 0.09334 seconds (78.87% PHP - 21.13% MySQL) with 10 queries
