Kenwood KAC-1023 crossover/gain board, same as in other *23-series?
Old 4th August 2010, 10:11 AM   #1
gisewhcs is offline gisewhcs  Germany
gisewhcs's Avatar
Default Kenwood KAC-1023 crossover/gain board, same as in other *23-series?
I have a KAC-1023 sitting here with the x-over/gain board missing.
Does anybody know if it could be substituted with such a board from other 23-series amps?
As I didn't find any good internal pics of any 23-series amp I even don't know if the smaller ones have the controls on such a subboard...
I think I can get a 823, to be a bit more specific!
Regards Julian
Old 6th August 2010, 07:43 AM   #2
gisewhcs's Avatar
No ideas, anybody?
Old 6th August 2010, 08:41 AM   #3
Perry Babin is offline Perry Babin  United States
I couldn't find any information on either amp.
Old 6th August 2010, 10:46 AM   #4
gisewhcs's Avatar
So I will have to spend the 5 (~4$) for the 823 and have a look for myself...
I the guy still has it...
Old 8th August 2010, 09:13 AM   #5
gisewhcs's Avatar
So, unfortunatly the board is NOT the same as in the 823.
The 823 has the status LED on the same board, in the 1023 it's on another small board.
Also the 1023 has one ribbon wire running to it, the board in the 823 uses two ribbon wires.
I believe it could be modified, but as I will get the original 1023 board I wont have to try that!
Old 30th October 2010, 08:29 AM   #6
xeclipse is offline xeclipse  Kenya
Location: Where the world's best tea come from:Kericho Kenya
I heard this amp last night,100 m from a van and it sounds awesome!Whats the power ratings?
if there are no sparks,it probably doesn't work!
Old 30th October 2010, 11:15 PM   #7
gisewhcs's Avatar
Here we go!
Kenwood KAC-1023
Old 25th January 2011, 01:24 AM   #8
BKLYNNY1 is offline BKLYNNY1
I have a Kac-1023 amp and love it had it many years and just yesterday it started blowing fuses gonna try to fix this amp hope it's a easy and not a costly fix...
Old 25th January 2011, 01:43 AM   #9
It probably has shorted output transistors if it only blows the fuse after the remote voltage is applied. You should disconnect all speaker wires from the amp, disconnect the RCAs and power it up. Does it blow the fuse?
I'd recommend using a single 20 amp fuse inline. You may be able to use only one 20 amp fuse in the fuseholders on the amp but some amps have separate circuits and require that all fuses be used. Four 5 or 7.5 amp fuses would be safe.
If the amp blows the fuse and you need help repairing it, start a new thread instead of continuing here.
Old 25th January 2011, 03:04 AM   #10
I will start a new thread....
Kenwood KAC-1023 crossover/gain board, same as in other *23-series?Hide this!Advertise here!
Kenwood KAC 8101D mike49504 Car Audio 5 14th May 2010 11:26 PM
kENWOOD 1023 mike49504 Car Audio 3 17th March 2010 02:12 AM
Kenwood KAC-X810D mike49504 Car Audio 2 20th February 2010 02:49 PM
Service manual for Kenwood KAC-1023 sdoom Car Audio 4 28th September 2009 01:27 AM
Kenwood KAC-X301T and KAC-X201T:Do they share the same board? spooney Car Audio 1 25th October 2007 02:08 AM
Copyright ©1999-2017 diyAudio
