Hi all,
I have a Pioneer KPX-9000 HU and I'm leaning towards getting an equalizer with a built-in amplifer for now, and upgrade to an equalizer with a preamp out later on when fund allows. If my understanding putting together a system is any good (doubt it), I have three possibilities for 4 speakers and a sub configuration. 1) HU->Crossover->Equalizer->Speakers & Sub Amp->Sub from the crossover 2) HU->Equalizer->Crossover->Speakers & Sub from the crossover 3) HU->Equalizer->Crossover->Speakers & Sub Amp with High Level Input->Sub from the crossover Do any of the above make (practical) sense? Cheers, Sam |
#2 |
Option 2 seems like your best bet. That being said a lot of crossovers also split the mids from the tweets (where you mention speakers).
#3 |
Some (maybe all) of the KPX head units had very low output signal (~70mv?) so they'll only work well with the old Pioneer component system components. This will limit your options.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
ok - what is the typical preamp output voltage for modern headunits?
so it's not simple as turning up the amp, then? - sorry about all these noob questions. |
#5 |
My headunit has 5V or 6V preouts (Pioneer Premier DEH-P980BT). I think most are in the range of 1-7V. This would mean your headunit is up to 2 orders of magnitude below the required range.
#6 |
Typical maximum preamp voltage for a normal/common head unit is between 2 volts and 4 volts. Most amplifiers can produce full power with input as low as 200mv but there aren't many that can produce full power with 70mv. Does your head unit have the output voltage printed on the label with the model number?
#7 |
Most of the texts on the label are not really legible. I consider myself lucky to have decyphered the model number to be honest...
I'll have a look though when I get home. Thanks guys. |
#8 |
nope - i can't read any other info on the label than 12VDC -ve ground...
| First (Noob) crossover project - upgrade klipsch RF-7 | okapi | Multi-Way | 32 | 1st August 2011 08:12 PM |
| Digital Crossover software setup for a noob... | sxr71 | PC Based | 9 | 18th June 2010 01:41 PM |
| Electronic Noob, crossover Problems | Deorum | Parts | 2 | 30th November 2008 04:02 PM |
| Noob question | dumbo800 | Tubes / Valves | 6 | 12th August 2008 02:43 AM |
| noob needs help designing crossover | helpmeplease | Multi-Way | 3 | 21st December 2003 11:22 PM |
| Page generated in 0.08634 seconds (76.23% PHP - 23.77% MySQL) with 10 queries |
