Nakamichi MB-100
On the back of the Tuner unit...
...on the right, there is a 6 pin conector (red, yellow, blue, blue/white, black and pink) I assume these wires are for power, ground, amp on, etc., but do not know which is which.
red= positive power source?
black= ground?
Blue= amp on?
yellow= illumination?
Blue/white= ??
pink= ??
...also on the right, there is a 12-pin male DIN plug, I assume this goes to the 24-bit D/A converter?
On the left...
...there is a white 10-pin slot. I have a pigtail with a 10-pin connector on one end that fits in that slot and has a 12-pin female DIN connector on the other end....what is this for?
...next to the 10-pin is a red 3-pin slot...for?
...under the red slot is a white 3-pin slot and under that is a white 2-pin slot.
What are each of these connectors for?
Thanks for your help so far...
Thomas
