Go Back   Home > Forums > General Interest > Car Audio
Old 22nd July 2010, 08:41 PM   #1
timwebb is offline timwebb  United States
Default driver signals
ok i was wondering do traces distort signals cause i was checking some drivers on an amp that i replaced and the wave is perfect at the driver transistor but at the gate resistor it changes. or could it be my scope?
Old 22nd July 2010, 08:48 PM   #2
For that type of signal, there will be no visible difference if the trace is intact. There will be a difference if you're looking at the base of the driver transistor and the gate resistor or if you're looking at the signal after the gate resistor.
Are you looking at the signal on the emitter leg of the driver transistor and the end of the gate resistor that's not connected to the FET gate?
Old 22nd July 2010, 09:03 PM   #3
its the same i have and ground issue with my probe i changed probe and there the same now.they are just old i guess
Old 22nd July 2010, 11:38 PM   #4
You can buy cheap scope probes on ebay. They're only about $10 each and have been reliable. Buy from a US seller to get them more quickly.
Old 22nd July 2010, 11:42 PM   #5
ok i was looking at some smd removal stations since most amps are using smd parts now that would be a good one for a good price i seen some on ebay from hong kong and dont know how well they work.
Old 22nd July 2010, 11:51 PM   #6
Unless you have deep pockets, you don't need an SMD rework station. What SMD component have you had trouble replacing?
Old 22nd July 2010, 11:59 PM   #7
i fix some pc mother boards and hard drives and car radios, and that chip quick cost alot the only place i can get it from where i live its like 25 bucks.
Old 23rd July 2010, 02:05 AM   #8
OK. I can't help. I've never needed anything other than chipquik and a soldering iron.
Y-cable for digital signals Ryssen Digital Line Level 2 9th November 2009 11:25 PM
Mixed signals??? genmin Car Audio 4 12th February 2009 06:58 PM
Routing I2S signals Predator864 Digital Source 13 18th March 2008 10:41 AM
Degaussing signals fmak Parts 2 29th April 2006 03:47 PM
combining 2 or more audio signals? r-wu Analogue Source 6 7th May 2003 10:10 PM
Page generated in 0.09142 seconds (75.29% PHP - 24.71% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
