diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   memphis 1500d (http://www.diyaudio.com/forums/car-audio/170555-memphis-1500d.html)
timwebb 21st July 2010 12:14 AM
memphis 1500d
ok im workin on the driver card for this amp can somone identify this part
A1381E
Perry Babin 21st July 2010 12:48 AM
http://datasheet.octopart.com/2SA138...et-5361519.pdf
Possibly ^?
timwebb 21st July 2010 01:27 AM
ok the protect light and the green light come on at the same time
mike49504 21st July 2010 05:05 PM
The driver board i have here out of a memphis 1500d has a A1301-e in it
timwebb 21st July 2010 07:47 PM
that would make both lights com on?
Perry Babin 21st July 2010 08:19 PM
Does the amp work properly?
If not, what are the symptoms?
timwebb 21st July 2010 08:40 PM
the power supply works fine it was a one output transistor over heating and i changed some transistors on a driver card cause the legs were rusted and the transistor stop over heating but i cant get this light to come off.i was going to see if it plays.everthing gets power and idle good.
Perry Babin 21st July 2010 08:46 PM
Does the speaker protection relay engage and remain engaged?
What is the DC voltage on the speaker terminals?
Measure the DC with the black probe on the ground terminal and also with the probes directly across the speaker terminals.
timwebb 21st July 2010 09:58 PM
the relay stays engage until it turns off but when i put the 9640's back in the green light starts blinking fast again should i rebuild both driver cards?
Perry Babin 21st July 2010 10:01 PM
In my opinion, you shouldn't replace any parts without having a good reason.
DC voltage readings?
Copyright 1999-2017 diyAudio
