Go Back   Home > Forums > General Interest > Car Audio
Old 20th July 2010, 02:22 AM   #1
Default Memphis 16-ST500D Protection Light
I have had this Memphis Amp for Years and it was fantastic for a long time. Well its been sittin around the last couple years because of not using it because when you power it up, you do not even get a green power light on it, you just see the protection light flicker on for a couple seconds then fade out, and you have nothing. Ive opened up the amp to look for fried parts inside of it and i don't see anything, im hoping it could be a simple fix and have this baby up and running again. I just tested it again in my brothers truck tonight, unhooked his amp and threw this on just to test it real fast and still doing it. I know there is good power and ground as his amp was just working right before just fine. Any Ideas? or is there anyone in the Cleveland, Ohio area who repairs amps? Any input would be appreciated.
Thanks.
Old 20th July 2010, 03:36 AM   #2
I repaired a couple of these a while back and a 1000. Not a whole lot to bringing them back to life in most cases. I don't live anywhere near you, Sorry.
Hope you can find a good local shop. Mostly bad outputs and bad caps, with a occasional blown power supply. Sometimes the D class driver board has failed transistors due to the fact they run hot all the time, even in perfect working order.
That info in the right hands should get you up and running in short order.
Old 20th July 2010, 05:51 AM   #3
timwebb is offline timwebb  United States
with those amps it could be anything
Old 20th July 2010, 07:44 AM   #4
Do the vertical boards have 2 rown of pins or 1 row of pins where they go into the main board?
Does the TL494/594 IC have pins that go through the board or is it a surface mount IC?
Memphis 16-mc1000d mike49504 Car Audio 46 9th July 2010 09:06 PM
Memphis 16-ST500D mike49504 Car Audio 19 17th December 2009 04:32 PM
memphis 16-pr1kd chev55_steve Car Audio 0 2nd January 2009 10:46 AM
Memphis 16-ST500d Repair help cccampbe Car Audio 8 20th November 2008 06:46 PM
memphis 16-ST500D frt96 Car Audio 2 9th May 2008 07:16 AM
Page generated in 0.08255 seconds (74.89% PHP - 25.11% MySQL) with 10 queries
