Current behavior:
turns on, runs for 10 or so seconds with distortion. Towards the end of those ten seconds i hear a faint very high pitched whine which sounds to be above 10khz. Then it shuts down for around 2 seconds, turns back on, and the cycle starts over. I suppose the whine is coming from one of the toroids in the power supply area but I have not tracked it down. When it is whining it seems like it is drawing a lot of current. I have not measured how much but it is enough to draw down my 12v power supply voltage a bit. Any pointers would be appreciated. |
#2 |
All channels?
These amps are VERY sensitive to voltage drop and dips that are so short that they don't show up on a multimeter will cause it to shut down. Are you sure that this isn't the problem?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
All channels were out when it was in the car. I took it in, put it on the bench, and it seems to be doing the same thing there (the repetitive turning off). It is possible both the car battery and bench power supply have problems but the JL 300/4 I swapped into the car is not having a problem and neither have other amps I have run off the bench PS so I think that is unlikely.
#4 |
Post the voltage on all 10 pins of the connector shown in the photo (view full size to read numbering scheme).
Post one set before it whines and one set after it whines. Before Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: After Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10:
#5 | |
Thanks, Matt |
#6 |
I didn't have a photo for the 500/5 with the numbers on it. Your amp has the same connector. It's labeled P800 on the board and it's near the power/ground terminals.
#7 |
P800, found it on the input board. Will take the measurements tonight.
#8 | |
1. as high as 18v, most of the time 11, falling to .5, then briefly back to 18 2. 45mv down to -20V 3. 11.3 dropping to 9.5 4. 11.4 dropping to 9.5 5 45mv rising to 2 6. 44mv up to 2v 7. 11.4v falling to 10 8. 12v falling to 10.6 9. 5v rising to 5.7 10. 12v falling to 9.6 |
#9 |
Are they numbered like those in the photo?
If not, repost them as they are numbered on the photo.
#10 |
Well, it is not the same board as the one shown in your picture so I don't see how to compare. I have included a picture I took. What I am calling pin 1 is the one in the top left.
| Jl 500/1 irf540n? | mbates14 | Car Audio | 10 | 26th June 2010 11:14 PM |
| jl audio 500/1 | megael9 | Car Audio | 12 | 28th May 2010 11:01 PM |
| Help with JL 500/1 2nd one | nsxxtreme | Car Audio | 51 | 7th March 2008 02:17 PM |
| jl 500/1 powers up but no sound HELP | fallenskater654 | Car Audio | 1 | 4th March 2008 05:17 AM |
| FS: JL 500/1 ($500 CAD located in GVA) | Dynamix Lude | Swap Meet | 0 | 27th October 2004 03:21 AM |
| Page generated in 0.10491 seconds (78.93% PHP - 21.07% MySQL) with 11 queries |
