Go Back   Home > Forums > General Interest > Car Audio
Old 18th July 2010, 11:00 PM   #1
Default hifonics zeus z4400
I have this amp in for repai. 1 of the outputs was shorted and 3 resistors were also shorted. I replaced the parts Amp is still stuck in protection mode.
So i pulled all outputs even know they tested good Amp is still stuck in protection mode any thoughts?
Old 19th July 2010, 12:45 AM   #2
The transistor that senses over-current in the blown channel may be leaking or shorted. It will likely have one leg connected directly to one end of the emitter resistor.
Old 19th July 2010, 01:12 AM   #3
Ok i replaced the transistor C3198 and still no luck amp still stuck in protection.
Is there a way to disable the output section to see if the power supply starts up?
Old 19th July 2010, 10:12 AM   #4
Removing the rectifiers should allow the power supply to start.
Old 19th July 2010, 01:43 PM   #5
I pulled the rectifiers and when trying to power it up the amp does nothing no lights nothing
Old 19th July 2010, 03:56 PM   #6
What's the DC voltage on the gates of the power supply FETs?
Old 19th July 2010, 04:19 PM   #7
With the rectifiers in the amp i get
leg1:0
leg2:13.90
leg3:0
With the rectifiers out of circuit i get
1:4.96
2:13.90
3:0
It appears to me the amp is powering up with the output section disabled.
So now i have to track down the problem in the output section.
Any idea on where to start since ive already replaced the transistor and the outputs are out of the amp right now
Old 19th July 2010, 04:26 PM   #8
The over-current protection transistors are connected together, possibly via diodes. Find the common connection trace that goes towards the power supply. Desolder and remove the jumper that makes the connection to the power supply.
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 05:31 PM
hifonics zeus viii transformer... marko Car Audio 33 3rd January 2011 07:43 PM
Hifonics zeus gen x mike49504 Car Audio 93 20th April 2010 11:20 PM
hifonics zeus xi mike49504 Car Audio 68 12th February 2009 05:23 PM
Hifonics Zeus VII redimp Car Audio 1 20th December 2006 10:47 PM
Page generated in 0.08820 seconds (74.16% PHP - 25.84% MySQL) with 10 queries
