Go Back   Home > Forums > General Interest > Car Audio
Old 18th July 2010, 09:13 PM   #1
ul9601 is offline ul9601  New Zealand
Default need some info on Pioneer KPX-9000 HU
Hi all,
I have a Pioneer KPX-9000 headunit but no amp to go with it (I'm led to believe GM-120 is the amp for it). Anyway, I'd like to hook it up to some other amp, so I need some (or any) info on the headunit - users' manual, service manual, schematics whatever.
Also, I'm planning to ditch the tape deck and build in an auxhiliary in jack for mp3 players.
Any help would be appreciated.
Sam
Old 22nd July 2010, 07:23 AM   #2
After some research and looking at GM-120 amp schematics etc, I think I figured out the pin outs for the massive 9 pin DIN connector.
But there is another connector, looks like a 6 pin DIN socket, which seems to come out of tuner PCB board, and it has a removable plastic cap which shorts a couple of adjacent pins with the cap on.
Any idea what this might be?
By the way, reading a car stereo article on Popular Mechanic April '79 issue, GM-120 doesn't look like it was the standard issue for KPX-9000 - the photo looks different than GM-120 & power output s lower at 20 wpc RMS vs 35 (I think).
Thanks,
Sam
Old 22nd July 2010, 03:29 PM   #3
I think the jumper was to bypass the processor loop (which was to allow the use of an equalizer) but I'm not sure.
Old 22nd July 2010, 07:00 PM   #4
ok - but what actually hooks up to the 6 pin DIN socket?
or is it just a jumper and nothing is meant to be plugged in?
9 pin DIN seems to have everything that needs to go to the amplifier, i.e. R & L (+ve) and a common audio ground, +12V, GND.
cheers,
sam
Old 22nd July 2010, 08:52 PM   #5
You'd plug in a pioneer equalizer, if I remember correctly. If you don't have an equalizer, you'd leave the jumper in place.
Old 22nd July 2010, 10:07 PM   #6
Cool - thanks so much, Perry.
Sam
Pioneer A-449 , Ask For Info everflow Solid State 2 1st August 2009 07:17 PM
Need info for Pioneer DAC PD2026B Assyst1606 Digital Source 2 22nd December 2008 08:05 AM
Who has info on Pioneer PD2026A DAC? electropt Digital Source 5 28th January 2008 10:55 AM
Pioneer HU - USB hard drive failing error401 Car Audio 5 5th November 2007 09:23 PM
Pioneer Deh-p6850 HU lens clipto333 Car Audio 0 3rd November 2007 07:52 AM
Page generated in 0.09083 seconds (72.49% PHP - 27.51% MySQL) with 10 queries
