diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   HIFONICS bxi 1606d (http://www.diyaudio.com/forums/car-audio/170146-hifonics-bxi-1606d.html)
timwebb 13th July 2010 06:06 AM
HIFONICS bxi 1606d
ok i have another one of these,the power supply is shot. what resistors and mofets would be good?
i read on another thread 47 ohms and IRFP064N just need to be sure thanks!
Perry Babin 13th July 2010 08:45 AM
What were the originals?
timwebb 13th July 2010 09:03 AM
FQP65N06 are the originals and 47ohm resistors
Perry Babin 13th July 2010 09:23 AM
FQP65N06
Mouser has the original parts.
The original is in a TO-220 package. The IRFP064 is in the TO-247 package so they're not interchangeable. I think there are two versions of this amp.
Have you checked the outputs?
Does it use the HIP4080 audio driver IC?
timwebb 13th July 2010 03:50 PM
yea everything is burned on this amp and it uses the HIP4080 audio driver.
Perry Babin 13th July 2010 03:56 PM
If it uses the IRF3710 outputs, order the Z version (IRF3710Z). Also order a new 4080.
Check the low value resistors and the large diodes near the 4080.
timwebb 13th July 2010 04:07 PM
i have some 3205 on hand will that work of testing till the new ones come?
timwebb 13th July 2010 04:09 PM
1 Attachment(s)
here's the board
Perry Babin 13th July 2010 04:10 PM
If you're going to install the 3205s, you may as well leave them. This drive circuit can handle the load. If you have a scope, check the drive signal on the gate pads for the power supply FETs before installing any new FETs.
timwebb 13th July 2010 08:37 PM
is it common for an amp to have diodes cause all the ones in this amp is are gone
Copyright 1999-2017 diyAudio
