HIFONICS bxi 1606d - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 13th July 2010, 11:18 PM   #11
timwebb is offline timwebb  United States
ok ive cleaned the amp off and the 494 is getting no power? on the bottom of the amp it has heat damage should i replace it?
Old 14th July 2010, 12:05 AM   #12
ok now its getting 12v and 4.95v on the third pin
Old 14th July 2010, 04:44 AM   #13
With the power supply FETs out of the circuit, do you read ~5v DC on the gate pad for every power supply FET?
Old 14th July 2010, 05:02 AM   #14
the protect light comes on now but goes back off.and im not reading anything
Old 14th July 2010, 05:48 AM   #15
ok i get 4v on the gate pads
Old 14th July 2010, 07:00 AM   #16
the 494 is putting out a good signal and i get a good signal on the gate pad
Old 14th July 2010, 01:41 PM   #17
m4ick is offline m4ick  United States
Wow, that amp is completely different from the bxi1606d I just fixed.
Old 14th July 2010, 03:12 PM   #18
the layout is different than what im use to dealing with brutus amps.
the 494 just started making a frying noise and them made a little smoke.what should i check before replacing this chip?
Old 14th July 2010, 07:14 PM   #19
4v on the gate pads should indicate that you have a good drive signal, especially if all gate pads had the same voltage.
What was replaced before you applied power?
Did you have the transistors tightly clamped to the heatsink?
Which transistors smoked?
Old 14th July 2010, 07:34 PM   #20
i changed four diodes cause they were leaking and checked the 494 and it was hot then i saw smoke come from it.
Hifonics Brutus BXI 2008D mike49504 Car Audio 13 17th February 2012 05:21 AM
Hifonics Brutus BXi 1606d parts Bertje Car Audio 2 3rd June 2010 04:33 PM
Hifonics 1606D & 1608D mosfets? Doffo Class D 1 24th October 2009 06:17 PM
Hifonics Bxi 1606d Please Help dmeche Class D 3 25th July 2009 08:15 PM
hifonics BXi 1606D burnt resistors??? gadgeteer123 Class D 7 30th June 2009 09:55 PM
Copyright 1999-2017 diyAudio
