Cadence Zrs 9000D - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th July 2010, 07:45 PM   #21
What sort of problem?
If it's out of the circuit, it's well out of tolerance.
Old 16th July 2010, 07:56 PM   #22
There are resistors i see that arent toasted in the power supply section.
And 1 of the caps 10uf 50volts keeps venting.
I called Cadence and they said the same as you did the amp will idle around 12 volts.
the resistor out of circuit reads 3219 ohms but it appears to have gotten hot at 1 point
Old 16th July 2010, 08:29 PM   #23
Does that resistor appear to be ok or out of tolerance (3K) neasure 3219 ohms out of circuit??
Old 16th July 2010, 09:51 PM   #24
150 ohms is out of tolerance but I doubt that 3219 ohms would cause problems.
The problem with the capacitor is a concern. Do you know what's causing it?
Is it an intermittent problem?
Old 16th July 2010, 10:16 PM   #25
I found a A1266 transistor burnt that was inline with the cap.
I also found a 220 ohm resistor burnt.
I have a new power supply board for this amp im gonna stick in.
So right now im going through the power supply section of it testing pretty much everything since i found resistors burnt and a transistor burnt. Also resistors out of tolorance .
cadence power transistor clips dynosaur Car Audio 1 28th July 2015 06:31 PM
Want to Repair Cadence TXA-1000D amp gexamb Car Audio 62 15th September 2009 06:00 AM
LED Model For Pspice, cadence and Orcad juanlara Parts 0 8th April 2009 08:54 AM
Cadence Ultrashock A5+HC tankdime Car Audio 0 18th September 2008 10:35 PM
cadence ZRS-10 schematic! mgm2000ro Car Audio 1 30th June 2006 08:47 AM
Copyright 1999-2017 diyAudio
