Go Back   Home > Forums > General Interest > Car Audio
Old 7th July 2010, 08:58 PM   #1
Default Bias adjustment for Punch150 transistor outputs
Is the adjustment the same as the fet based outputs? Normally I monitor the voltage across my current sense resistor in series with incoming power and watch for it to take off. I then back it off a touch. I don't notice the "take off" point on this amp.
Cory
Old 7th July 2010, 10:20 PM   #2
I think all Rockford amps tend to increase significantly at some point. Which components did you replace in the audio section of the amp?
Old 7th July 2010, 11:39 PM   #3
I didn't adjust far enough, about 3/4 turn of the pot it finally increased like I expect. Most of the newer amps don't get much past half turn before they increase. That is why I ask the question.
This amp had blown Buz11's in the power supply and one channel had a shorted 2n6487 and 2N6490. This amp was untouched when I got it, all components were originals, no signs of rework. The bias pots seem to be in the same position as when I recieved it.
Bias Adjustment point LarryRup Tubes / Valves 1 3rd July 2010 07:03 PM
Fixed Bias adjustment alexmoose Tubes / Valves 9 12th June 2009 02:32 PM
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
Bias adjustment question n0plb Tubes / Valves 20 5th May 2005 01:21 PM
Page generated in 0.05234 seconds (79.73% PHP - 20.27% MySQL) with 10 queries
