Go Back   Home > Forums > General Interest > Car Audio
Old 5th July 2010, 01:28 PM   #1
Default RF 400x4, output channel distortion
Hi guys,
New member here, first of just to say this looks to be a great forum with some very knowledgeable people. Unfortunately I have a problem with my rockford fosgate punch 400x4.
I had this amplifier connected in 4 channel stereo mode, it initially had a problem where one of the front channels would sound distorted, I swapped the RCA's and the output channels round and bizarrely the problem was solved.
Now since recently disconnecting the amplifier and re installing it I can now connect the front channels up as normal with the red/white rca going in the correct way and can connect the left channel to the left speaker and so on.
But the rear right channel now sounds distorted while the rear left seems to play clear. I swapped the rca's around, changed the rear right speaker and the problem was still there. I then connected the rear right speaker to the rear left channel and the problem was solved and connected the rear left speaker to the rear right channel and that still played a distorted signal.
This seems strange as I have tried to swap the rca/output channels around like last time but the problem is still evident.
I have removed the amp and had a look at the circuit board and all the joints seem to be in good condition. The REM connection also came loose and I have re soldered that in and that works 100%. I don't know what to look for when checking transistors/resistors/FET's and I don't have acess to a scope or a bench.
I have good soldering skill and a multimeter, can anyone please advise what could possibly be the problem and how I can resolve this issue?
Many thanks!
edit: just to add I also swapped the crossovers from the front and pass through to the rear crossovers and the problem was still there, I also have a spare 60ix from which I can borrow the crossovers from and can swap into the 400x4 if the above was not the correct way to go about this.
Old 5th July 2010, 03:25 PM   #2
Something to look for are leaking caps, the small 10uF ones littered about the board. Also check the ground shield on the rca jacks, those can be loose. The crimp lets loose and they don't make good connection.
Old 5th July 2010, 05:15 PM   #3
Thanks brandes, I have had a look at the rca's and they seem ok to me, also there are no leaking capacitors.
I swapped the crossovers over from my 60ix and the problem is still there so its not that.
After a bit of reading and a youtube guide I have increased my knowledge somewhat.
Using a multimeter I measured the resistance at the speaker terminals (with the multimeter set at 20k ohms):
Rear L: 9.24
Rear R: initially 1.22 but over a period of 1 min it rises to 6.30
Front L: 9.19
Front R: 9.22
Also I checked the transistors on the speaker side of the amp and have drawn the following diagram and below are the relevant readings:
With the mulitmeter set on 2000 ohm I got the following readings:
1: 308
2: 015
3: 306
4: 306
5: 307
6: 305
7: 308
8: 306
So would I be correct in thinking that replacing transistor no2 will increase the resistance at the rear right channel and therefor provide a clean signal?
If so what transistors will I need and would I replace the whole of the top row or the top and bottom?
Many thanks!
p.s here are some hi res pictures of the amp, can anyone identify any defects?
Possibly some corrosion on the first two channels? Which are the rear channels btw.
The second transistor in this picture is the one with the low reading ( top left of the amp)
Old 5th July 2010, 05:49 PM   #4
#2 does appear to be defective. Which legs did you have the meter probes on when you measured the resistance?
Old 5th July 2010, 06:21 PM   #5
Hi Perry I measured from the 2 outer probes, is that correct?
Old 5th July 2010, 08:28 PM   #6
That's a common reading for failed FETs, especially if they're using BUZxxx transistors. Generally shorted FETs cause excessive current draw but when these FETs short from leg 1-3, they simply cause the output to be distorted. Check the gate resistor on the shorted FET after removing it. Re-check the FET after removing it to confirm that it's shorted.
Old 5th July 2010, 08:30 PM   #7
R352 is open.
Old 5th July 2010, 09:23 PM   #8
Wow well spotted, will replacing this resistor solve my distortion issues?
Looking at the circuit board for the other channels I think I need a 100ohm resistor (R452), is that correct?
Thanks!!
Old 5th July 2010, 09:55 PM   #9
There's no guarantee that this will return the amp to proper working order. This may be the extent of the damage but it's possible that there are other problems. You should also check Q321. You'll have to remove it to check it properly.
10 ohms.
Old 7th July 2010, 03:32 PM   #10
Hi perry, I know its a totally newbie thing to do but could you please do me a favour and link me to what resistor and and transistor I need to replace R352 and Q321.
The website I wish to use is Welcome to rswww.com
The number currently stamped on Q321 is mps a56 m529
RF 250a2 1.9Vdc on output brandes.cm Car Audio 24 7th October 2009 12:53 AM
Why older RF amps always blew up with DC in output valterdaw Car Audio 10 18th August 2006 02:15 AM
Need Help: RF 500S amp with tonns of DC in output valterdaw Car Audio 5 23rd June 2006 03:35 AM
distortion in one channel randytsuch Chip Amps 1 3rd October 2003 07:25 PM
channel distortion sriegel Pass Labs 15 13th February 2002 06:23 PM
Page generated in 0.11735 seconds (81.13% PHP - 18.87% MySQL) with 10 queries
