#11 |
Vishay | Passives | Resistors | Surface Mount, Fixed | Thick Film - 0805 |CRCW080510R0FKEA
They don't stock the MPSA56 but the following transistor should work. ON Semiconductor | Semiconductors | Discretes | General Purpose Transistor | PNP Small Signal |MPSA92G
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#12 |
Thanks Perry,
I managed to remove the transistor and it seemed to be working at it should, I had a reading from both the outer legs when the middle was connected to the ground on the multimeter diode test. When the legs were switched so the positive is on the middle leg there was no reading when the negative was on the outer two legs. And when both the outer legs were tested against eachother the circuit remained open So I have placed an order for the resistors and will let you know how I get on Cheers |
#13 |
Ok guys, sorry for the late update, the supplier of the resistors was out of stock until last week and I have just soldered the replacement resistor in.
The problem still remains, with the resistance on the rear right channel showing 1.22 and steadily increasing. Anyone able to tell me what to check next? |
#14 |
List all parts that you have already replaced.
Check the following: Q312 Q313 R363 R336
| RF 250a2 1.9Vdc on output | brandes.cm | Car Audio | 24 | 7th October 2009 12:53 AM |
| Why older RF amps always blew up with DC in output | valterdaw | Car Audio | 10 | 18th August 2006 02:15 AM |
| Need Help: RF 500S amp with tonns of DC in output | valterdaw | Car Audio | 5 | 23rd June 2006 03:35 AM |
| distortion in one channel | randytsuch | Chip Amps | 1 | 3rd October 2003 07:25 PM |
| channel distortion | sriegel | Pass Labs | 15 | 13th February 2002 06:23 PM |
| Page generated in 0.08420 seconds (76.86% PHP - 23.14% MySQL) with 10 queries |
