Image Dynamics ID10 no so loud. Image Dynamics ID10 no so loud. - diyAudio
Old 29th June 2010, 05:52 AM   #1
asianvenom is offline asianvenom  United States
Default Image Dynamics ID10 no so loud.
First of all, I'm new to this forum, and would like to say hello to everyone...!
Well I just purchase a pair or ID10 version 3, DVC 2ohms from Image Dynamics, I don't feel that its getting loud enough. I'm running it off of an JL 500/1 amp at 2ohms load. Gain set all the way down, boost bass at 0, crossover at 80hz infrasonic set at 60hz. I've notice that the sound is getting warmer, but not louder...
Please advice...
Old 30th June 2010, 01:15 AM   #2
praveenz is offline praveenz  India
praveenz's Avatar
From what i ve heard ID CTX, IDv3 are purely into SQ and hence wont be that loud.
Only ID Max is very loud (as well gives good SQ)
The IDQ is also relatively louder than CTX and ID
Old 30th June 2010, 01:53 AM   #3
1moreamp is offline 1moreamp  United States
as I recall this is a filter, and your filter is set very close to your crossover point. Perhaps you might try lowering the "infrasonic back around 30 or 20. I see amps come into me with similar issues and this filter is set too close to the crossover point thus removing a lot of bass information.... Almost every time I see this issue, the setup plays a lot louder once the subsonic filter is set appropriately. This filter can relieve boominess of the system but at a cost and if used incorrectly will render you bassline muted....
Old 30th June 2010, 03:39 AM   #4
update: As this subs get some playing time to break-in, it is suprisingly getting very warm, tight, and deep bass. I am quite impressed with this subs.
1moreamp: I did a lil research, and someone mention that's for power consumption? either way, I'm not familiar with it, so i turn that feature off.
Problem now is with my amp. It would play for a bout 10-15 minutes and the sounds go away, amp remains on but no sound, no thermo error. Originally the "off/12db/24db" octave setting was set at "12db", i turn it to off position, and the sounds come on again, but I have not have a chance to listen to it long enough to tell that it will remain on. This issue never occur before with this amp, and I have this amp over 6 years.
I'll keep everyone update,
Thanks for you respond.
Image Dynamics ID10 no so loud.Hide this!Advertise here!
Image Dynamics Q-1200.1 Class AB Amp aemixes Swap Meet 1 11th July 2009 04:17 AM
Image Dynamics idMax 12 D2 V.3 aemixes Swap Meet 1 27th April 2009 10:05 PM
Image Dynamics Q-1200.1 Class AB Amp aemixes Swap Meet 3 27th April 2009 10:04 PM
Image Dynamics IDMAX 12" as Home Sub? HiggityHank Multi-Way 5 17th March 2003 09:28 PM
Image Dynamics IDQ12 Sub BennySP Multi-Way 0 17th May 2002 07:12 AM
Copyright ©1999-2017 diyAudio
