Hey guys,
I bought a Rockford Fosgate Amp and Sub off craigslist about 2 months ago and they worked great until the other day. My sub just stopped working but my amp was still working fine. I went on and bought a kicker L5 from my friend and it worked great... for two days. Idk if my amp is burning out my subs but it shouldnt be. The amp is a 600 amp with 200 rms. The new speaker is an 600 watt with 300 rms. Is there a reason why it stopped working? Help would be appreciated! Thanks. Chris
#2 |
Perhaps you were pushing your amp too hard - this will cause failures faster than an amplifier with 100w (RMS - other values have little or no meaning) more than needed.
Have you checked all the connections etc? If they're Ok, use a meter to measure the DC voltage on the output. DC cooks speakers effectively. (another) Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
Thats what I'm starting to think. When I was going to work today it didnt work but when I went out for lunch it did. Then on the way home from work it stopped working. It didnt do this for the whole 2 months I had it. Why now?
#4 |
Some versions of the L5 and L7 had problems with broken lead-in wires. If the wires are broken, it could cause the speaker to work intermittently.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 | |
What rockford amp is it? If its an older 200 dsm it will put out way more than 200rms, especially if you use the incorrect load when bridging it to the sub.
Don't worry... you can always turn the gain down! |
| Sony TA-AX380 Stopped Working | rudypoochris | Solid State | 46 | 18th June 2010 10:21 AM |
| Amp Stopped Working | twhittle14 | Car Audio | 28 | 17th June 2010 05:23 PM |
| el84 1 channel stopped working help | eddiedavies | Tubes / Valves | 5 | 2nd April 2007 11:32 AM |
| pinnacle 850 stopped working | jamesj2 | Multi-Way | 1 | 14th February 2005 09:48 AM |
| Page generated in 0.08129 seconds (69.45% PHP - 30.55% MySQL) with 10 queries |
