I recieved this amp in for repair and the outputs where shorted i replaced all of then Irf540's I put new Irf540N's back in it. I also replaced the 47 and 10 ohm resistors.
Amp powers up But its not producing NEG rail voltage . Any thoughts on what to check? |
#2 |
Most of the JL class D amps have no negative rail voltage.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
So on the Irf540's 2 of them have 70 volts on the middle legs the other 2 no voltage present on them. Is that normal or is there a problem somewhere?
#4 |
One group of parallel outputs should have rail on the center leg. The other group of parallel outputs should have their 3rd leg connected to ground. The 3rd leg of the first group and the center leg of the second group should be at 1/2 of rail.
#5 |
Ok with black probe on ground terminal 1 group of outputs 70 volts of rail on middle legs.
Next group of outputs red probe on B+ terminal i have 13.8 volts on 3rd legs What do i need to check next since i have no output ? Also dont know if this helps or not but only have the green LED's are lit on the board |
#6 |
Do you have 0v DC on all of the speaker terminals (black probe on ground terminal)?
Is the protect LED lit?
#7 |
No Dc on any output terminals. Proctection light is not lit.
I noticed the regulators 317 and 337 are getting hot very quicly though |
#8 |
Do you see a square wave on any pin of either of the ICs marked HC132 on the driver board?
#9 |
any other way to check it? I need a new scope mine was sitting on the shelf and came crashing down and hit the floor now it doesnt work right
#10 |
I don't know enough about this amp to check it any other way.
| jl audio 500/1 | megael9 | Car Audio | 12 | 28th May 2010 11:01 PM |
| Jl audio 1000/1 | mike49504 | Car Audio | 1 | 22nd May 2010 08:21 PM |
| jl audio | nicandjade | Swap Meet | 0 | 2nd September 2006 10:35 AM |
| JL Audio vs Polk Audio | xfsrg | Car Audio | 2 | 17th October 2004 06:09 AM |
| Page generated in 0.09657 seconds (76.72% PHP - 23.28% MySQL) with 10 queries |
