As I'm planning to spend some new caps to my girlfriends amp I'm wondering what's the railvoltage for the subchannel?
The schematic just says "Sub-Rail", great! ![]() The other channels run off +/-26,5V as the schematic tells me, so 35V rated caps would be ok. It's still in the car and I don't want to/have time to remove it for measuring. As I have the schematic and some hi-res pics of the board it wouldn't be a problem to order the parts. Because I want to spend some extra capacitance to the secondary and you don't have much hight in the sink for bigger caps, I need to know the railvoltage of the subchannel. I don't believe it needs the 50V rated ones, so I can maybe look out for flat ones with higher capacitance that will fit in there. |
#2 |
The 405s appears to have approximately 45v on the high-power setting.
There's probably no point in replacing the capacitors unless they're defective.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I just saw the transformer ratio in the schematic, 3/10 in the high power setting and 3/8 in high current.
So you are right with something around 45V. I wanted to change them because the amp has a little turn-off pop in the subchannel, and I hope replacing the caps and resoldering the whole thing will solve this. It's definitive not caused by a bad chassis ground or the radio, double checked that already. As the amp already had bad solderjoints on one of the normal channels' FEB, I believe this is a good piont to start with. And I don't know who used or abused this amp before, and the caps are from somewhat around 1995 or so... I nearly always put new caps in such old amps, preferring Panasonic's FC Series. |
#4 |
If I'm not mistaken, this (turn on/off noise) was a common problem and not easily solved. Maybe someone has dealt with this before and can provide a bit more information. I think there was a similar problem in a thread for a 705.
#5 |
I just read through nearly all Soundstream threats and found something about a pop issue in an threat about an MC245.
I believe that design is a bit too different from mine to be comparable, right? In that threat an, I believe ex Soundstream engineer, mentioned some kind of relay board being added to that amps to get the problem solved. I think, I will give resoldering and recaping (correct english?!) a try first. |
| Newbie Soundstream ref 604 repair | remoteaudio | Car Audio | 48 | 1st April 2010 07:27 AM |
| soundstream ref 604 schematics | lexneedssound | Car Audio | 30 | 19th February 2010 05:11 PM |
| Blown Power Supply: Soundstream Ref.200s | gisewhcs | Car Audio | 7 | 23rd November 2009 10:38 PM |
| Soundstream ref 414s Problem | mrFrog | Car Audio | 16 | 11th June 2007 06:45 PM |
| soundstream reference 405 problem | suprmanDL | Car Audio | 3 | 21st January 2005 07:46 PM |
| Page generated in 0.08230 seconds (73.07% PHP - 26.93% MySQL) with 10 queries |
