I got this amp in for repair . It had no output so i removed the board from the sink and redid some solder connections.
With the board out of the sink it will power up and produce audio. If i put the board back in the sink and put all clamps back in the amp will power up fine but not produce audio and the rca jacks will spark like the heatsink has voltage. Something conducting?? Or what might cause this |
#2 |
With it clamped down and no power applied, what is the resistance from the B+ terminal of the amp to the RCA shield?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
2.032 k ohms and it continues to climb
#4 |
Try twisting the transformer to see if it changes.
#5 |
Twisted the transformer and got 3.92 k ohms now. Left channel produces clean audio right channel still dead
#6 |
Does the heatsink have any voltage on it?
Do the RCA shields have any AC or DC voltage on them? Check with your scope as well as your multimeter.
#7 |
Heatsink has 45.2 volts on it. Rca jacks have -0.72 volts on them
#8 |
Check the resistance from the tabs of the rectifiers and outputs to see if any are shorted to the sink.
#9 |
Check isolation between power transistors and heathsink.
Some amplifiers used metal anodized isolators, and these can break down. |
#10 |
Ok i found one shorted to the sink.
I took the entire board out of the sink again since the right channel still doesnt work. I see alot of crappy solder joints on this board so i will re solder them and see it i can get this amp up and running. |
| Kole XP2-2000 trouble | mbates14 | Car Audio | 11 | 21st February 2010 05:34 PM |
| Kole KX1-5500D in protect mode. Shorted diode? | barros57 | Class D | 2 | 13th February 2010 01:41 PM |
| For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp | tmort | Swap Meet | 5 | 27th June 2009 12:29 AM |
| [UK] 2x Pro Audio C12 - 300MB & 2x Pro Audio PST888 Tweeters for Sale | makksus | Swap Meet | 0 | 3rd November 2008 12:12 PM |
| Kole Audio Amp Problem...HELP | dozan1 | Car Audio | 4 | 14th February 2007 06:51 AM |
| Page generated in 0.09595 seconds (77.09% PHP - 22.91% MySQL) with 11 queries |
