I recieved this amp in for repair. I pulled the first 2 legs of the power supply fets off the board. Leg 3 is still solderd to the board. I also pulled the rectifiers and power supply drivers in this amp.
I still read a short directly across power and ground terminals of the amp. Wondering what could cause this?? Transformer maybe?? |
#2 |
D1-d3?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I lifted 1 side of D1,D2,D3 out of the board And i still read a short between positive and negative terminals
#4 |
If there are no other large diodes and the FETS are out of the circuit, I'd suspect a solder bridge.
#5 |
I looked over the entire amp i dont see any solder bridges and no other diodes.
The amp worked for a few secs when it came in but then started drawing high current and reading shorted |
#6 |
Does it read shorted with your meter as well as drawing high current when connected to 12v?
#7 |
It reads shorted with my meter. And draws high current with just power and ground hooked up to the amp.
#8 |
It's possible that a primary filter capacitor has failed but that's unlikely. Have you cleaned all of the flux off of the board around the power supply FETs and examined the area with a magnifying glass? Sometimes a tiny thread of solder can be hidden in the flux and cause this problem.
#9 |
I will clean it right now and let you know in 5 mins
#10 |
Perry,
I cleaned the board . Guess i overlooked the first time i found a solder bridge between legs 1 and 2 for one of the power supply fets. Next question is The guy had this amp hooked up in his car. He ran 4 guage wire to it. And he added a 2.5 farad cap. When he had it up and running he said the amp was not as loud as it should be . He said it was only putting out 1/4 of its power and his 600 watt amp was louder. I told him that his ground and power wire was way to tin for the amp and that his ground wire was also to long (3 ft). He then told me that the cap he has in the car went from 13.90 volts down to 8 volts with the amp playing and now the cap wont turn on at all and the amp has very low output. Anything i should check for when putting it back together? |
| Help with MA Audio HK1000D | shawnk | Car Audio | 12 | 22nd February 2010 06:30 PM |
| Ma Audio HK 4000d works but some fets are burnt | scrub50187 | Car Audio | 7 | 21st April 2008 06:51 AM |
| MA Audio 802sx help | judtoff | Car Audio | 2 | 12th November 2007 02:25 PM |
| MA Audio HK4000 | Tom7227 | Car Audio | 1 | 16th September 2007 10:07 PM |
| MA Audio vs. Dayton | ZuMbAiU | Subwoofers | 7 | 30th January 2006 01:29 AM |
| Page generated in 0.09898 seconds (77.26% PHP - 22.74% MySQL) with 10 queries |
