Go Back   Home > Forums > General Interest > Car Audio
Old 17th June 2010, 01:47 PM   #1
Unhappy kicker amp problems!HELP ME FIX IT?!
i have a mono block kicker amp that i have hooked up many times hoping it would work.when i hook it up it sounds killer at a low volume.then when u turn it up it makes the sub kind of pop...then the last time i hooked it up it blew something out inside my head unit that runs thru the sub rca's because when u would change the song there was sub woofer activity constantly that would not stop even if u turned the sub out all the way down,the only way to make it stop was to unplug the sub rca's all together.and this was true when i completely removed the amp and put my old one back in.i took the amp apart and cant c anything visibly wrong with it.i really want the thing to work!can anyone help??
Old 17th June 2010, 03:30 PM   #2
m4ick is offline m4ick  United States
Sounds like there is a problem in the amp sending voltage across the RCA shield.
There is a fuse in your head unit tying the RCA shield to ground. It's blown. You can open the HU and replace the fuse or run a fused jumper from your RCA shield to the chassis of the HU.
If the amp is at fault, it will pop the fuse again. Not sure what's happening inside the amp, though.
Old 17th June 2010, 08:47 PM   #3
IT could have a transformer that's shorted from the primary to the secondary.
With the amp powered up and no RCAs plugged into the amp, what's the DC voltage on the input RCA shields of the amp?
Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the RCA shields of the amp.
Kicker ZR 240 problems, should be simple fix cavhooah Car Audio 18 4th March 2012 12:01 PM
kicker zr 600 problems turboeeyore Car Audio 4 6th November 2009 02:48 AM
kicker DX700 problems ben04srt Car Audio 9 18th January 2009 10:05 PM
polk componets & Kicker 352xi amp Failure skooter Car Audio 9 4th September 2008 10:00 PM
Perpetuum-Ebner PE66: To fix or not to fix... Grendel the Cat Everything Else 0 6th April 2007 05:37 AM
Page generated in 0.07853 seconds (71.52% PHP - 28.48% MySQL) with 10 queries
