my alpine 3553 amp got flooded a while ago, all the 2sd1669 ( 6pcs ) blew so i replaced them, now the amp works but runs extremely hot and draws 5 amps, even without speakers attached. any suggestions on what to do? a tech guy here said i should adjust the bias, any one care to explain how this is done?
#2 |
With all transistors clamped tightly to the heatsink, does the heatsink heat up under the power supply transistors (the ones you replaced) or under the output transistors?
If it gets hot under the outputs, the bias may need to be adjusted, especially if someone has moved them from their original setting. It's also possible that some component has been damaged by the moisture and that's causing the overheating.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
If it turns out not to be the bias:
Were the old transistors isolated from the heatsink, or was the heatsink isolated from the chassis previously? |
#4 |
its heating up under the power transistors i replaced, it only takes a couple of minutes to get really hot. turns out there are no provisions to adjust the bias, i dont see any trim pots. the transistors are clamped to the heat sink, any suggestions what to check out next?
#5 |
I don't have any information on that amp. Can you post a photo of the inside of the amp (specifically the area near the transistors you replaced).
#6 |
#7 |
There are 1 and 10 ohm resistors just in front of the power supply transistors you replaced. You need to check each of them to confirm that they're within tolerance.
If those are OK, check the C3852 transistors. You will need to desolder them to check them.
#8 |
i checked the resistors and they read all 1.5 and 4.5, i attribute the 4.5 ohm reading to the fact that its connected to the transistor. i replaced the c3852 transistors, turns out they weren't bad. Now the power supply goes up to 10 amps when i turn the amp on! what did i do wrong?
#9 |
Remove the resistor and re-check it.
#10 |
rechecked the resistors, they're .5 ohms over spec, is that a big deal? or is that within acceptable spec?
| Dynaco ST-120 runs hot | bobgroger | Solid State | 6 | 15th April 2008 05:20 AM |
| OPA4228 runs hot | iron25 | Solid State | 2 | 1st July 2007 05:42 PM |
| power acoustik one channel runs hot | montecarlossfan | Car Audio | 7 | 21st June 2005 01:10 AM |
| Alpine 3519 car amp running hot | Mark25 | Car Audio | 4 | 14th October 2003 05:40 PM |
| BOSOZ's PSU runs very very hot | ruangrit | Pass Labs | 18 | 5th February 2003 11:45 PM |
| Page generated in 0.11551 seconds (81.89% PHP - 18.11% MySQL) with 11 queries |
