Go Back   Home > Forums > General Interest > Car Audio
Old 16th June 2010, 10:01 AM   #1
Unhappy Another brutus problem !
firstly can i say hey to all on here,
now my problem i have a 1206 brutus and i have read through the other brutus problems but have not seen anything really matching my problem.
i recently brought it off ebay and was told fully working when i recieved it and tested it did not work so went through a huge argument with the guy and rar rar rar
well i got my refund through ebay and still have the amp (guy told me to go f*** myself so i guessed he didnt want it back :P)
well everything all powers up, now when connected to signal lines and speaker (used an eminence delta free air as i had it spair) you can hear the out put but its nothing more than background music when up full ( i have an alpine up front running i think 4 v ) so im a little confused and not to transistor and fet minded so yeah
thanx in advance craig !
Old 16th June 2010, 01:09 PM   #2
m4ick is offline m4ick  United States
have you tried hooking up another amp to see if it improves?
is the subwoofer in an enclosure?
Old 16th June 2010, 01:41 PM   #3
You should try operating all controls/switches through their entire range to see if the audio output increases. It could simply be a dirty contact.
If it's something that simple, you should pay the seller for the amp.
Old 16th June 2010, 07:09 PM   #4
i did spend a few hours on it and i know the speaker is all ok, i havent touched it in a while but i am going to get it out and try again could i try switch cleaner as on my big sound i use it and cant see a prob on 12v systems ?
also I have the same problem with a friends 1210 that was brand new, the fuse holder doesn't hold the fuse and he had to keep pushing it back but then spazzed out again and is now doing the same as my 1206. on the 1210 it just turned off one day and found out it just decided to not like the ground and at that point he changed the ground with no problems and continued to power properly with no problems !
it seams like it is powering at the lowest level it can!
and its not me lol i have a 2608 and i have had that in and out and droppped it and just basically abused it and it still works to this day !
so ....
Old 17th June 2010, 12:09 AM   #5
As long as the contact cleaner is safe for plastic, you can use it on the switches. Moving them with the amp on would make the problem of dirty contact immediately obvious because the sound would play through intermittently.
If you determine that it's definitely not the switches, you would need to measure the voltage on several points in the amp to determine what the fault is.
Old 17th June 2010, 01:50 PM   #6
ok thanks how likely is it to be dirty contacts ???
will test tommorow and report back
thanx
Old 17th June 2010, 07:20 PM   #7
Also if its not switchs what would i do with my friends as its still tech under warrenty but lost warrenty paper work ?!
Old 17th June 2010, 08:55 PM   #8
Determine if it's the switches first.
Old 17th June 2010, 11:40 PM   #9
OK now i need help lol
just tried the amps again tonight and there all fine ?????
wired in and tested all switches and gains all smooth and true
but i know they were doing nothing as i have the same set up as i did the last time i tested
any clue because im just loosing my mind over this lol
Old 18th June 2010, 02:05 AM   #10
Dirty switch contacts are the most likely cause if the amp was powering up normally (power LED on, protect LED off).
Hifonics brutus bx1500d mike49504 Car Audio 33 17th April 2011 10:46 PM
Hifonics Brutus BX1500D FireII Car Audio 5 24th May 2010 03:08 AM
brutus 1600w timwebb Car Audio 56 19th May 2010 06:12 AM
Hifonics BXi2006D Brutus! Formas Class D 0 30th August 2009 05:25 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 05:36 AM
Page generated in 0.10857 seconds (81.42% PHP - 18.58% MySQL) with 10 queries
