Go Back   Home > Forums > General Interest > Car Audio
Old 14th June 2010, 06:03 PM   #1
Default JL audio 300/4 sucessfull repair, but questions...
I've had a JL 300/4 sitting on the shelf for a while now. After some research on here, I decided to dig into it's low ohm issue. One output transistor tested low on the board and bad once I pulled it, it was replaced.
I was successful in solving the issue, and the amp now has what seems to be normal output.
I'm driving a set of 3-way MB quart Q series speakers. While this amp was down I was using an older 4 channel Kenwood amp that was loud, but not necessarily clear. Deck is a new Alpine CDA-9886 with 4V preouts.
Last night I used JL's instructions to set the gain. With no processing on the deck and the volume at 3/4 I was looking for 17.3V per channel. I could achieve this on either high or low input settings.
Question is this. It's very clear sounding, even near full volume on the deck, the issue is I can turn it up to full volume and it really could stand to be louder. I have ran these speakers with this amp before (but not this deck) and I do remember it being able to drown out the noise from my diesel.
Anything I should be looking at? Some other component in the amp, bi-wiring, bridging a side to each pair of channels maybe?
Sorry for the long post
Old 14th June 2010, 10:14 PM   #2
I know of no one that was ever satisfied with the gain set as JL suggests. That doesn't mean that it's not a proper way to set the gains. Most people want to be able to drive their amps harder than they can with the gains set that way.
Old 15th June 2010, 02:10 AM   #3
I ended up bridging each channel, helps a lot.
JL 300/4 - First Amp Repair greg_gorrell Car Audio 27 1st August 2009 09:59 AM
jl audio 300/4 repair brianfulcher15 Car Audio 3 16th June 2009 05:45 AM
Help to repair JL audio 300/2 Solosound Car Audio 42 20th March 2009 12:52 AM
JL Audio 300/4 PQatPIT Car Audio 5 4th March 2009 02:06 PM
jl audio 300 2 ppia600 Car Audio 2 6th April 2008 03:54 PM
Page generated in 0.08086 seconds (67.63% PHP - 32.37% MySQL) with 10 queries
