Does anyone have the part # for those parts, the schematic doesn't list it. The 60.2 schematic which is identical lists that zener a 1n5366, which is 39Volts.
The reason I asked the above question.... I had this 250a2 donor board laying around and this 60.2 that I just picked up for $7. It had blown supply fets, replaced those and all is well. I happen to compare the 250a2 pcb with the 60.2 and noticed components and values are identical. So basically I updated the 60.2 with the mesha strips from the 250 and thought why not transplant the xfrmer as well. This worked, but the output remains the same as with the original xfrmer. Maybe the xfrmers are identical as well, but I don't think so, my previous measurements from other 250's I would get 22Vrms across a 3 ohm load. The 60.2 I get 18Vrms across 3 ohms. Curious if I could get 250 like power from the 60.2, honestly the specs are not to far off. Must be another difference that I haven't noticed. Cory |
#2 |
The SMD zener and the 5366 have nothing to do with the regulation. The 5366 clamps any inductance leakage spikes that may occur. The SMD zener works to do the same thing but they use the FETs to do the clamping.
What is the duty cycle of the square wave on pins 9 and 10 of the TLx94 IC?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
It is switching at 31Khz.
#4 |
The duty cycle is the percent of the time that the drive voltage on pin 9/10 is high for each cycle. If you have a scope, you can calculate it.
If the duty cycle is very low with no load, the voltage is being regulated and you'll need to change the value of the resistors responsible for regulation. If you have the schematic diagram, send me a copy and I'll tell you what needs to be replaced. babin_perry@yahoo.com
#5 |
Sorry, I know what duty cycle is, just spaced out there. The duty cycle is 1%, the positive pulse is ~480nS.
I don't have the electronic copy at home, you can grab the pdf from my site: https://sites.google.com/site/brandescm/home/projects Are you talking about secondary side regulation? |
#6 |
I don't see the 60.2 there. Is one of those equivalent?
#7 |
The 250a2 circuit is identical to the 60.2. I need to update that page with all the schematics I have.
#8 |
What are the values of R4, R5, R17 and R18 in the 60?
#9 |
R4 18k
r5 10k r17 110k r18 110k |
#10 |
Are you sure that R4 isn't a 10k?
| Pioneer PD-D9-J Service Manual | Baka | Digital Source | 12 | 1st October 2010 06:47 AM |
| Rockford Fosgate 250a2 | mike49504 | Car Audio | 4 | 28th April 2010 02:38 AM |
| RF 250a2 1.9Vdc on output | brandes.cm | Car Audio | 24 | 7th October 2009 12:53 AM |
| Sansui au-d9 service manual | mosfet1 | Solid State | 1 | 1st October 2008 02:49 AM |
| Page generated in 0.11059 seconds (80.56% PHP - 19.44% MySQL) with 10 queries |
